Home > Puma (Tdci) > Interior lights not working
Page 2 of 2 <12
dumptruckface
England 2012 Defender 110 Puma 2.2 XS DCPU Orkney Grey
check out my post in the electrical section, i have the wiring/plug for the 10as module, this can be found if you remove the drivers under dash speaker, this might be your problem if water gets into this module it will play up your interior light etc.
Post #495240 22nd Jan 2016 5:40pm
barbel jim
Thanks, I read your thread, coupled with a few comments on this one makes me think its water issues! It has stopped in the main now (dried out) but did flicker on once or twice on the way home yesterday. I did notice whilst taking the screw out that holds the switch in drivers door post it was wet on the exposed threads in the post. I havn't had any noticeable water issues, and the footwell has only been wet once in 5 months. There is nothing obvious, and I'm loathed to fiddle too much, let the warranty boys sort it out !
Post #495455 23rd Jan 2016 9:05am
Flyingfocrs
Scotland 2011 Defender 110 Puma 2.4 USW Santorini Black
Just had something similar
Get in and head down road, few minutes later either the interior lights would flicker or eventually just come on.
Eventually narrowed it down to the passenger door.
Got to the point that when i locked the doors the alarm would sound even with all the doors shut.
Squirt of water displacing fluid into the switch and worked it a few times manually and it's been fine since.
Post #495472 23rd Jan 2016 10:14am
barbel jim
That is almost exactly my symptoms, except they are constantly on and take a while to go off, then flicker randomly. They are fine today. Just mucking it out and I have noticed a few water stains from leaks Whistle it is also wet under the front floor mat, drivers side Rolling Eyes
Post #495489 23rd Jan 2016 11:48am
Nipalong
England 2015 Defender 90 Puma 2.2 SW Corris Grey
Hi Littledave12,
I had the same issue and then my alarm would sound when I locked it, I took it to Landrover as its only 5 months old, the wiring to the light sensor was not connected properly.
Worth having a look
Post #501770 7th Feb 2016 5:16pm
Page 2 of 2 <12
