Home > Maintenance & Modifications > Britpart LED headlight up grade...
Page 2 of 2 <12
Cupboard
Might be an idea to put a lumens rating on the advert on your website before being too critical of someone else being vague about theirs Thumbs Up Smile
Post #501746 7th Feb 2016 4:20pm
leeds
Looks like my work is done! Razz
I have got people reading adverts more closely. Thumbs Up
Yes we have missed that specification out on our web page. Embarassed
Will ask Barbara to check it out.
Specification is Lumen / Lumens (LowBeam/HighBeam) 1880lm / 2400lm (calculated) ~1550lm/~1700lm (measured)
We do have the full correct specification on our printed leaflets.
People wanting the full specification can find it here
If we have made any mistakes or omitted any key information please let us know and we will try and rectify any mistakes/omissions we have made.
Brendan
Post #501772 7th Feb 2016 5:23pm
Rolling with laughter
Post #501809 7th Feb 2016 7:18pm
ericvv
Brendan
How much is that in "raw" and "effective"? Whistle Thumbs Up
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #501818 7th Feb 2016 7:27pm
Cupboard
Rolling Eyes
Raw/calculated/theoretical/gross...
Measured/effective/actual/net...
Which is where I'm running in to problems on the Night Breaker thread.
Post #501825 7th Feb 2016 7:37pm
leeds
If I make a mistake I will stick my hand up Embarassed
Yes it does happen at times, hopefully not too often and we will do our best to sort things out as soon as possible.
Just remember we are a small company with limited resources.
Brendan
Post #501848 7th Feb 2016 8:11pm
leeds
Cupboard wrote:
Rolling Eyes
Yes it can be confusing!
Lets try a few basic definitions
Watts = SI unit of electrical power = volts x amps = electrical power consumed.
There is no direct SI connection between power consumed and light output or lumens
Lumen is the SI unit of visible light output.
OK some people argue you can calculate lumens from watts by using
Lumens = luminous efficacy x watts.
However luminous efficacy is not a SI unit and will vary between different LED's and different drivers etc.
Raw lumens is a theoretical calculation of the light output where everything is working perfectly, the driver is working 100 % perfectly, there is no temperature rise etc
This is the 100% perfect figure however in real life few things run 100% perfectly
Raw lumens could be described as the 'headline' figure as it is the highest figure which the light system could possibly give out.
Raw = theoretical = gross = calculated
That is the simple one.
If there is only one figure for light output then it will be the raw lumen figure.
Effective lumens
Defined as raw lumens minus theoretical losses due to inefficiencies in the driver, losses due to electrical, optical, thermal losses etc.
Read this
Measured lumens
Get your light source and physically measure the light output by a photometric device
Measured lumens is the best figure to have but not many manufacturers supply this figure.
HTH
Brendan
LUX is how bright light is on the ground. One lux = 1 lumen per square metre or about full moon light
Post #501899 7th Feb 2016 9:32pm
Page 2 of 2 <12
