Home > Maintenance & Modifications > problem fitting roof rack
stricko
Hi
I have been assembling my new roof rack today and have it now sitting on the roof of the 110.
However when I fit the brackets which secure it to the gutter, the front four are catching the doors when they open.
I have been looking to see if I can find a local metalworker who could mill the brackets down slightly and will call a few tomorrow.
I was just wondering though if its easy to drop the doors by a couple of millimetres or so without it starting to leak (and no, it doesn't already!).
thanks in advance. ---------------------------------------------------------------
Post #501667 7th Feb 2016 1:19pm
rustyboxx
United Kingdom 2015 Defender 90 Puma 2.2 CSW Montalcino Red
I had the same problem with my 110. Adjusting the height of the doors by dropping the hinges slights sorted it out without any leaks Thumbs Up 2015 90 XS CSW TDCi - Beautiful
2007 110 XS DCPU - An itch that needed scratching
2005 90 Td5 XS CSW - Utterly brilliant
2001 Discovery 2 ES Auto - A phase I went through
1996 90 Tdi CSW - Uber reliable
1989 90 2.5 Petrol Hardtop - My first proper Landy
1985 Range Rover Vogue V8 -Troublesome
Post #501671 7th Feb 2016 1:28pm
stricko
Thanks - is it easy to do? ---------------------------------------------------------------
Post #501674 7th Feb 2016 1:31pm
rustyboxx
Yeah, a doddle. Only loosen of the torx head bolts enough to enable moving the door up and down. I used a wide wooden spatula as a lever underneath the bottom of the door to assist in moving it up and down to get it right. You might have to adjust the door catch to suit the change in height also Thumbs Up 2015 90 XS CSW TDCi - Beautiful
Post #501685 7th Feb 2016 1:51pm
stricko
All done - cheers Thumbs Up ---------------------------------------------------------------
Post #501698 7th Feb 2016 2:27pm
rustyboxx
Excellent Cool 2015 90 XS CSW TDCi - Beautiful
Post #501700 7th Feb 2016 2:34pm
lonewolf
United Kingdom 2010 Defender 90 Puma 2.4 CSW Zambezi Silver
Since you lowered the doors what are your shut lines like now? I had the same problem with my 90 with the drivers door. I dropped the door a tad but not too much but also ground a little off the bracket. In the end you only need a fag papers width after all. The passenger side wasn't a problem as it had 6mm clearance, that's build quality for you eh? Confused
Post #502346 8th Feb 2016 8:44pm
apt100
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Aintree Green
Out of interest, what make is the rack?
Post #502372 8th Feb 2016 9:32pm
lonewolf
Hi apt100, mine is a Front Runner rack, but I don't blame the rack itself, when you look at the difference in height from the two gutters and corresponding doors the blame sits squarely (or lopsidedly in this case) with how my 90 was put together. Funny thing is that the doors match up with the body contours fine.
Post #502829 9th Feb 2016 8:12pm
apt100
Thanks for the reply.
You would still like to think that a rack being sold for a Defender would take into account the legendary build quality Laughing Although to be fair it probably isn't specifically designed for Def.
(I once bought an Halfords rack for a Vectra that rubbed the top of one of the doors. After a bit of whinging and sulking from the Manager I got a refund. I then shelled out on a genuine Vauxhall one that fitted much better with loads of clearance.)
Post #502833 9th Feb 2016 8:20pm
stricko
As it turned out I only needed to lower the passenger side doors a tiny bit. The driver's side were fine.
The doors all shut fine. I had to alter the catch slightly on the rear passenger door, the front was ok.
The roof rack was from MM-4X4
It was the cheapest priced one I could find (at £444 + 56 for the ladder) It needed to be self assembled (I dont know if others do or not?) Its very solid once built and I have been up on top and it supports my weight ok.
Here is a pic.
Post #502984 10th Feb 2016 5:47am
lonewolf
Alls well in the end then. I had to assemble my frontrunner rack, it looked more like a bedframe when it was assembled, I hadn't thought about how big it would be.
Your rack looks very snug atop your 110.....enjoy Smile
Post #503221 10th Feb 2016 6:47pm
