Home > Puma (Tdci) > Bit of tlc |
jerseyman Member Since: 21 Jul 2009 Location: Jersey Posts: 279 |
They have a 6 year anti-corrosion warranty. But corrosion is defined as perforation. So the quick answer is no.
However, if you moan and kick up sufficient fuss and possibly talk to Land Rover direct you may persuade them to get it done as a goodwill gesture. (I managed to get some ali-corrosion sorted on my TD5 that way). However you do need to have a full service history otherwise you are probably stuffed with both options. Brian |
29th Dec 2010 5:58pm |
DefenderOfTheEarth Member Since: 09 Nov 2010 Location: Cornwall, UK Posts: 1304 |
Cheers! It does have full main dealer history. Defender 110XS SW gone... now VW California 180 4 Motion.
29th Dec 2010 6:11pm |
