Home > Puma (Tdci) > Warranty Work |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
Steering stops are arbitrarily set. Always need adjusting.
29th Dec 2010 12:52pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5035 |
Nothing wrong with a freelander!
I mean to check my steering stops - as mentioned they are set by science Some blue smoke at start up is common and normal The high range popping out thing could be poorly adjusted linkage - but it could also be driver error, ive seen it pop out a few times when you think its in properly...its a quirk (or charactoristic). Mike |
29th Dec 2010 6:49pm |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 |
my old 300tdi 90 had a really good turning circle. the Puma was rubbish until i adjusted them my self.......now as good as the old 90.
only took about 15 mins and is straight forward. BM52 |
29th Dec 2010 9:49pm |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
don't adjust the lock stops to far or could over load the c/v joints on full lock 2.4 90 XS
30th Dec 2010 9:21am |
