Home > Wheels & Tyres > Swingaway wheel carrier with hi-lift jack mount
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
Hi guys,
Looking for a swingaway spare wheel carrier for my 03 TD5 which has a mount for my new hi-lift. Needs to open with the door too please.
Thanks.
Pete.
Post #50060 28th Dec 2010 10:01pm
Lorryman100
How about this:
If you want one get it HERE Thumbs Up
http://www.defender2.net/forum/topic4659.html
Post #50061 28th Dec 2010 10:05pm
markb110
http://www.extreme4x4.co.uk/acatalog/REAR_WHEEL_CARRIERS.html
Try this as it has the high lift mount that you are looking for
Mark
Post #50064 28th Dec 2010 10:23pm
Zinke
Mark
Perfect! Exactly what i was looking for!
Thanks
Pete.
Post #50069 28th Dec 2010 11:05pm
leeds
Or this one?
I wonder where it is made? Whistle Whistle
Brendan
Post #50070 28th Dec 2010 11:09pm
Zinke
Ive got a hardtop though and want it to open with the back door.
Pete.
Post #50071 28th Dec 2010 11:12pm
leeds
That is the only photo that I have which clearly shows the hi lift jack mount.
This one shows swing away wheel carrier on a 09 110 USW but no high lift jack mount.
Now I wonder where that extreme one is made? Not that I know Whistle Whistle
Give you a clue. Made in West Yorkshire, don't ask me how I know or I mighthave to kill you Razz
Brendan
`ps `whilst I remember, please note that all rear bumperettes are not compatible wih swing away wheel carriers
Post #50077 28th Dec 2010 11:47pm
Glynparry25
Or the OE light guards Wink
Just another option.... http://www.kaymarcarrier.ru/products/jackm...lderkaymar
That way you can choose whatever wheel carrier you want and then bolt the jack holder to it.
Glyn Sheep
Post #50078 28th Dec 2010 11:53pm
Zinke
Brendan
You must know something i dont Embarassed
So you will need to give me a clue please!
Pete.
Post #50080 29th Dec 2010 12:06am
leeds
Glyn Sheep
Or NAS style lights. Guess how I know Razz
Remember f you alter position of O/S light you have to move the N/S one as well
Brendan
Post #50083 29th Dec 2010 12:19am
Vixen
Australia
My advice is to stay away from this type
Broke within 12mnths of purchase. OK...so was replaced under warranty Very Happy
Replacement broke 14mnths after it was attached to the defender Sad
Poor design.
Post #50084 29th Dec 2010 12:21am
BigMike
Zinke, it's from WMV / Safari Equip.
Post #50085 29th Dec 2010 12:44am
landy andy
The one from Safari Equip/Exteme, does move the wheel very much to the side of the vehicle, which is a look that I personaly do no like.
Just mentioning it so that you are aware.
Andy
Post #50100 29th Dec 2010 10:19am
Zinke
Thanks Andy i had seen that too, im not sure about it. I have been thinking about making my own but normally ends up costing more than a bought one and all the time and agro that goes with it.
I quite like Glyn's idea but dont think it will work with boost alloys??
Pete.
Post #50113 29th Dec 2010 12:40pm
leeds
First I suppose a couple of statements of interest.
1) I have used WVA/Safari Equip gear for a number of years on my own Land Rovers
2) I am a reseller of WVA/Safari equip gear. Their factory is about 2 miles away from where I live but apart from reselling some of their gear I have no other connections with the owners of WVA/Safari Equip.
Have used Safari Equip gear for a number of years including the swing away wheel carrier. The one on our red 110 is about 7 to 8 years old and carries a 255/85/R16 BFG MT on a steel modular. The red 110 has not had an easy life and has done tens of thousands of miles off tarmac. Have not experienced any problems with it and have had it modified to provide a mount for a HF aerial.
As a private individual they have made one offs for me so as a private Land Rover owner I am very happy with the service and quality of gear I have had from WVA. As a private individual have their diff guards, R+T sliders,wheel carriers etc
2) As a reseller of some of their gear I was in their offices about a week prior to Christmas. On a desk was what appeared to be the top bar of a swing away wheel carrier. I asked Jullian a partner in WVA about it. Yes they had experienced problems with some of their swing away wheel carriers. They normally sourced steel from a company which gets steel from UK/Europe. They had problems getting supplies of certain steel tube sizes from their normal supplier. An alternative supplier who got steel from India coud supply required tube and at a slightly cheaper price then normal supplier. Apparently all the failures in their swing away wheel comes from this batch of tube.
They are not the first company to have experienced problems with their goods after a change n supplier.
I will quite happily point out the pros and cons of any gear we sell WVA/Safari equip is no different.
Good points?
In general there stuff is well made and reasonably priced for the quality. i.e. their swing away wheel carriers varies between ca. £160-210. On ebay different makes varies between £130-280 (ignoring the alisport one at £600) The top mount is a long mount rather then the much shorter mount used by some other manufacturers.
Their protection gear is hot dipped galvanised then powder coated rather then the cheaper electro plated or just painted.
They are prepared to do one off specials. They do their best to resolve problems
Some bad points.
Their website! Lack of fitting instructions (they normally sell to garages etc and they assume that the fitters know what they are doing. I personally think they should at least put instructions on their website. Hot dip galv, they don't always check that tapped holes have not been clogged. Sometimes the fitting kits are a bit of a hit and miss affair.
Yes I can understand Vixen being annoyed and personally I do not blame her!
Yes as a reseller there has been a couple of minor issues which I have been able to resolve quickly. Probably helps that I am so close to their factory. Yes they have room for improvements
Hopefully that will help to clarify what has happened
Hope I have not overstep any forum boundaries
Brendan
Post #50159 29th Dec 2010 7:50pm
