Home > Technical > Dash Light problem
MM44MM
Australia
Dash Light problem
HI All,
Recently I went through deep flash flooding across a road & since then whenever it rains both the ABS & Traction Controls dash lights both stay on for the journey & some times longer. It apears that both ABS & traction control systems work fine.'
Is there anything either under the bonnet or underneath some where else tnhat could causde this please?
Mark Very Happy
Post #499759 2nd Feb 2016 11:26pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Long shot but some crap could now be I between the abs ring and the sensor, might be worth a quick check also ensuring the gap is correct. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #499762 2nd Feb 2016 11:35pm
MM44MM
Australia
Hi Mash,
Thanks, but being a bit of a dummy with these things - where is the 'ABS Gap' & how big should it be?
Thanks
Post #499765 2nd Feb 2016 11:44pm
Mash
Ok so after a quick read up as I'm not posh enough for one of these shinny ones with abs Whistle
The sensors seem to be through the axle casing, I think you need to remove the calipers and disks in order to gain access, the air gap should be around 1/4".
You can test the sensor without removing it with a fluke, it's a case of disconnect the cable (I think the connection is in the engine bay, trace it up from the axle it will be the only cable) setting the fluke to ac millivolts and with the wheel jacked up, ignition on. Spin the wheel and a voltage of 50-700mv.
This is knowledge off other platforms but I am sure it is the same if not someone more knowledgeable than myself will be along soon, if you have any doubts in working on the braking system leave it to someone competent Thumbs Up 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #499818 3rd Feb 2016 9:20am
jimbob7
Sounds like a sensor fault,it could be damaged wires anorl so your gonna need to go looksy,the wires run into the abs ecu under the seat (TD5).You can either disconnect each sensor (there's another connection maybe 18" from each sensor,or test it at the ecu which you need wiring diagram.As for spacing you can't measure them front or rear as there is no access (for measuring purposes).You simply push the sensor in so it touches the ring, then slowly spin the wheel which pushes the sensor back out. Pov.spec,ftw. 2006, 110,TD5.
Post #499860 3rd Feb 2016 11:04am
OP - what vehicle model are you taking about - if you complete the profile bit, it may help people direct you to the right answer.
Post #499921 3rd Feb 2016 2:18pm
MM44MM
Australia
Defender 110 - 2010
Post #500180 3rd Feb 2016 11:44pm
If you check all the wheel speed sensors for physical integrity as suggested then I'd move on to other parts of the system and check the harness plugs to see if they have any water in them or are not fully engaged and so letting water in.
Start with the Hydraulic Control Unit under the bonnet - it has two multiplugs to the rear and a third underneath.
The ABS Module is located in the right hand seat box and has 3 multiplugs.
Finally, if all this is OK then you need to get someone to plug a scan tool into your OBD and read any stored DTCs - there a shed load of them applicable to this system and it will help point you in the right direction.
If all this means nothing to you and you fancy finding it all for yourself then the Workshop Manual can be download from here:
https://onedrive.live.com/?id=4BC2D89C85C7...9C85C7C171
courtesy of dgardel Thumbs Up
Post #500289 4th Feb 2016 11:01am
