Home > 130 > Wheel spacers for defender 130 |
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1361 |
Should be fine Ben
1st Feb 2016 1:35pm |
ben-yates Member Since: 19 Oct 2015 Location: Lancashire Posts: 14 |
Good news,
Cheers mate |
1st Feb 2016 1:38pm |
HI Ben. Should be fine. Although I drive a Defender that is 20" shorter than yours, I have run wheel spacers for nearly a decade now and my truck is never empty and has a full roll cage to add to the weight. They make a super difference. What I will say is that with 30mm spacers and 285 tyres you are definitely going to need extended wheel arches. Also, when you fit them use threadlock on the spacer retaining nuts and torque them up properly, a case of learning through experience this...
1st Feb 2016 5:33pm |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1860 |
Sorry to jump in here but hopefully relevant. I've seen Raptor 30mm spacers on a well know web auction sight at just under £100 posted - anyone know if they are respected brand? Rob
1993 200tdi 90 hard-top 1998 300tdi 90 soft-top 2016 2.2 XS 90 hard-top (sold) |
1st Feb 2016 5:39pm |
Plenty of people run 285's with standard arches. Is it because his is a pickup? |
1st Feb 2016 6:36pm |
david110 Member Since: 11 Dec 2009 Location: Stirlingshire Posts: 81 |
Yes, 130 HCPUs don't have rear spats fitted as standard. Going to fit rear ones to mine soon.
1st Feb 2016 10:01pm |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3707 |
Spacers will be fine you will probably have to fit arches to the rear.
The shape and radius of the tub arch is not the same as the 110 or 90. 130's have feeling's as well you know |
1st Feb 2016 11:50pm |
