Home > Maintenance & Modifications > Re-attaching small rear window trims with clips
YOLO110
Australia
HELP!
I have now given up trying to work out how to re-attach my 2 rear quarter window trim panels!
They came off easily with a trim removed tool... 2 'sprung' type clips remained loose on the rear interior body and they seem to locate into the 2 u shaped clips inside the trim.
I cannot work out how these click back in place!
Can anyone advise please... I am certain this is not THAT complicated!!
Cheers,
Peter. Rolling Eyes YOLO... You Only Live Once...
Post #498508 31st Jan 2016 8:35am
ibexman
Atach the small end to bodywork
Post #498509 31st Jan 2016 8:49am
YOLO110
Australia
Sorry... don't understand??
The 'clips' are exactly as they were when I took the trim off. Aside from sliding down the rear frame once the trims were removed... YOLO... You Only Live Once...
Post #498511 31st Jan 2016 8:55am
NormanD
England 2015 Defender 110 Puma 2.2 USW Santorini Black
Remove them from the bodywork, squeeze the Trim side with pliers to get a very good fit to the Trim, attach to Trim Panel, refit Trim Panel to Bodywork. NormanD WE191
2015 110 XS Utility
2014 VW Caravelle 180 Executive
Post #498516 31st Jan 2016 9:01am
YOLO110
Australia
If I understand correctly...
Take the metal clips off the bodywork, insert them with the same orientation directly into the 'U' shaped mounts on the trims... but I will need to squeeze these metal clips tightly with pliers to get them to fit inside the 'U' shaped trim mounts...
Is that right? Thumbs Up YOLO... You Only Live Once...
Post #498525 31st Jan 2016 9:13am
Correct.
As above, the clips are originally fitted to the trim first, you have pulled them off the trim and they've stayed on the body.
Post #498540 31st Jan 2016 9:40am
ericvv
Anybody have the part number for these clips and where to best order them? I have taken those trim panels off and back on again numerous times, and just would like to have some of those clips in storage for future use.
Tks, Eric You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #498542 31st Jan 2016 9:47am
YOLO110
Australia
Many thanks to you all!
All of this to fit a rear 'Scenelite'!!! Laughing
For 'next' time... is it possible to remove the trims in such a way that the spring clips stay attached to the trims? YOLO... You Only Live Once...
Post #498544 31st Jan 2016 9:47am
You can be incredibly careful and gentle and some stay on the trim, some stay on the vehicle, some ping off and some break in half Confused
Post #498548 31st Jan 2016 10:09am
YOLO110
Australia
I will count myself bloody lucky then...
One went in one eye, the other in the ear.
I cannot see what I am doing now... sorry, what did you say! Laughing YOLO... You Only Live Once...
Post #498554 31st Jan 2016 10:36am
R1200GS
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Keswick Green
Tks, Eric
Part number BTR6682-BRP Edge Clip is quoted on my invoice from Devon 4x4 they cost 40p each plus VAT.
Just brought 4 yesterday after one of mine broke during removal......the other one stayed on the body work.
Great timing for this thread for me 😀
Post #498560 31st Jan 2016 10:56am
RRUK
Pete,
Each time I've removed mine one clips stays put and one stays on the trim, it's a matter of seconds to put them back on the trim piece.
How have you wired in the Scenelight? Have you out an in line switch or anything? 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #498561 31st Jan 2016 10:57am
ericvv
R1200GS wrote:
Tks, Eric
Thanks, BTR6682, that's them
Post #498563 31st Jan 2016 11:05am
YOLO110
Australia
RRUK wrote:
Pete,
Hi Mate,
Yes I have installed it! After much deliberation and checking, I used the feed off the interior lights, taking it from the rear one. The Scenelite is a pretty low current drawer... after a moment on here of checking panic!
I ran a feed to a switch that I installed on the rear RHS panel. From there, up to the light. I relocated the rear screen washer nozzle to the LHS of the rear door. It all worked well.
Pictures...
Switch install,
Light and washer location
Light ON! Its Soooo BRIGHT!
A lot of (enjoyable!) work for a 'simple' job... but if there was a 'next time', as usual it would be a LOT quicker!
Cheers,
Pete Very Happy YOLO... You Only Live Once...
Post #498578 31st Jan 2016 12:09pm
