Home > Technical > SVX Hi Beam Not switching off
LittleFoot
Hi all,
I posted previously asking if anyone with the SVX lighting cluster had experienced an issue with full beam jamming on? The hi beam utilises the 2 small lower spots not the main Wipac crystal headlight (now an led) and occasionally jams on.
Most severe time I stopped vehicle and switched off ignition and colum and the 2 spot lights still stayed on for 1-2 mins before shutting down. Any ideas? Some one said there's a relay under the passenger seat that may be the suspect?
Thanks
Post #498294 30th Jan 2016 5:30pm
ericvv
You have the SVX double headlights and the main 7" headlamp replaced by LED?
Do you have more than that, front fogs or DRL maybe?
I can only say one thing, when 4 years ago my dealer replaced my Wipac H4 halogen 7" headlamps by Speaker EVOs it proved not to be really plug'n play. The LED lamp electronics got totally confused by the fogs and I had similar issues where the 90mm aux high beam lamps were staying on when they shouldn't etc.
Final solution was installation of extra relay over and above the normal ones to also completely isolate the negative feed to the EVOs from all other electrics. Since that was done all works fine.
Sorry, I have no diagram to post here, dealer did it, but believe the EVOs in the end had 3 relays in total. Now that I have gone back to my Wipacs it all stayed in place and continues to work perfectly.
As to this....
The high beam actually uses simultaneously the 2 aux 90mm driving lamps plus the high beam of the Wipac 7" halogens, or in your case if you have installed 7" LEDs, the high beam of those LEDs. If it is different and high beam only is the 90mm aux driving lamps, it is wired up wrongly.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #498298 30th Jan 2016 5:41pm
LittleFoot
Thanks for your input Eric.
My symptoms started from new when the vehicle was original so I'm sure the LED headlight swap is not the trigger. However your symptoms are the same as mine - it's the small high powered aux light that stays on.
Post #498300 30th Jan 2016 5:46pm
