Home > Puma (Tdci) > Metal pipe blowing noise.
dilukabey
2009 Defender 110 Puma 2.4 SW Keswick Green
Hi guys, just started to experience a noise/whistle almost like "blowing a metal pipe" for a second, when accelerate suddenly specialy at 3rd gear. This noise is mild but can be heard if you listen carefully. Any ideas please,? Cheers
Post #498143 30th Jan 2016 3:21am
ericvv
You have a Puma 2.4 like myself, right?. Sounds to me like a splitting turbo to intercooler hose. Happened to myself too, whistling noise under power, but ok to drive at moderate speed. I was able to make another 50km at the time before getting to my dealer to replace it.
Not expensive to replace by original, can also be replaced by better quality stainless pipes as I did last year (Entreq) which will give you peace of mind forever.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #498156 30th Jan 2016 7:36am
Eduardo
As Ericvv said in the 2.4 version, the Turbo Hose is the most common failure that produce whistles (happens to me twice).
The other is a warped exhaust manifold.
Cheers! Eduardo
Post #498242 30th Jan 2016 1:03pm
dilukabey
Hi. Many thanks for the replies. The turbo hose failure has happened to me also once sometime back. But this time I suppose very much different to earlier.
"Blowing metal pipe" whistle sound only heard for 1 second when you just attempt to accelerate suddenly on the road and then it goes away no matter how hard you accelerate.
I have shut down the Egr inlet and outlet pipes sometime back and wonder whether this has something to do.?
NB. My car is 2.4tdci RHD and I guess the noise comes from left side.
Post #498484 31st Jan 2016 2:58am
