Home > Puma (Tdci) > Metal pipe blowing noise. |
dilukabey Member Since: 17 May 2011 Location: Sri Lanka Posts: 173 |
Hi guys, just started to experience a noise/whistle almost like "blowing a metal pipe" for a second, when accelerate suddenly specialy at 3rd gear. This noise is mild but can be heard if you listen carefully. Any ideas please,? Cheers
30th Jan 2016 3:21am |
You have a Puma 2.4 like myself, right?. Sounds to me like a splitting turbo to intercooler hose. Happened to myself too, whistling noise under power, but ok to drive at moderate speed. I was able to make another 50km at the time before getting to my dealer to replace it.
Not expensive to replace by original, can also be replaced by better quality stainless pipes as I did last year (Entreq) which will give you peace of mind forever. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
30th Jan 2016 7:36am |
Eduardo Member Since: 28 Aug 2008 Location: RegiĆ³n Metropolitana Posts: 2110 |
As Ericvv said in the 2.4 version, the Turbo Hose is the most common failure that produce whistles (happens to me twice).
The other is a warped exhaust manifold. Cheers! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
30th Jan 2016 1:03pm |
Hi. Many thanks for the replies. The turbo hose failure has happened to me also once sometime back. But this time I suppose very much different to earlier.
"Blowing metal pipe" whistle sound only heard for 1 second when you just attempt to accelerate suddenly on the road and then it goes away no matter how hard you accelerate. I have shut down the Egr inlet and outlet pipes sometime back and wonder whether this has something to do.? NB. My car is 2.4tdci RHD and I guess the noise comes from left side. |
31st Jan 2016 2:58am |
