Home > Puma (Tdci) > Have you experienced a reliable Puma?
Page 7 of 7 <1234567
Ecco
Malaysia 2014 Defender 110 Puma 2.2 DCPU Galway Green
..mine is july 2014 model..20K km on the clock..no issues, except rubber hose from turbo(which is already fixed with proper one+clips)..im changing oil every 5-6K km, even LR said every 10K (i change myself so they dont know)..but just now i read that some folks here changing every 20K? I do change oil for my P38 as well, every 5k km and it never failed on me for over decade now (i follow very sharp pattern of maintenance and on smallest signal that something needs attention, i replace with brand new part)..but now, out of curiosity, what should be oil change interval, which guarantee that engine functionality is not affected on negative way ??
Post #477346 29th Nov 2015 1:57pm
sven
Norway 2009 Defender 90 Puma 2.4 SVX Soft Top Santorini Black
Mine is a 2009 SVX 90 soft top - km 40000.
No problems at all:) 2009 Land Rover Defender 90 SVX Soft top 60th Anniversary Edition
Post #477372 29th Nov 2015 3:04pm
Trundlebus
2.2 130, 2 years old, never missed a beat.
Post #479269 5th Dec 2015 9:14am
Smurph
2012 Defender 110 Puma 2.2 SW Keswick Green
2012 ,110 ,SW now with 60000 kms. Very reliable.
2 problems: top radiator hose leak from contact with power steering reservoir hose clip ( noticed before any damage). Intercooler hose crack. replaced with silicone hose.
This vehicle has been used mostly offroad in Zimbabwe, South Africa and Botswana.
Post #494558 20th Jan 2016 9:19pm
AlanH
Australia
Mine hasn't exactly missed a beat but it's had more than it's share of time off the road having things fixed or replaced. The last 3 things are the VCV, Aircon evap unit ($AU3K plus about 1K when some idiot mobile mechanic tried to fix it) and now the main fuel tank has a split and needs a replacing.
The writings on the wall large and clear, my continuing ownership of this Censored heap is not long .....
AlanH.
PS. The Cook will kill me I know but some prices are worth paying. Laughing
Post #497300 28th Jan 2016 9:14am
216lcg
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Java Black
I bought mine new in May 2007 so an early one. It has only covered 40K and only on tarmac but the only problem i have ever had is a leaking power steering box about 2 years ago replaced by staffs 4x4.
Post #497344 28th Jan 2016 10:42am
Dasher
2015 Defender 110 Puma 2.2 USW Santorini Black
Mine's done 66K miles and is a December 2010 2.4 Utility XS. Only the one problem (well two in one really) - The clutch failed at 50K miles - the well known torque springs issue. This was fixed on the last week of warranty with no issues. It was then taken out on road test and the mechanic felt that the mainshaft bearings were done for. LR agreed and a complete new box was fitted under warranty. One of the most reliable LRs that I've had (and I'm into double figures - 5 of which have been from new).
I pick up my replacement 110 Utility XS from Hunter's on Saturday - I'll be well happy if it behaves like the current one. If anyone is looking for a good XS Utility that is VAT qualifying then speak to Hunters as this one is destined for auction and I've been very happy with it. It has just come back from accident repair (literally - this week). It was a relatively low speed full front impact - no damage past the repeater indicators - so it has new wings, new radiators, new bumper, new front tyres. Absolutely no chassis damage.
Post #497475 28th Jan 2016 5:13pm
louiskemp1
25,000 miles on the dot.
2013 2.2 90 HT. Bought at 4,000 miles an an ex-demo.
16,000 Miles - Immobiliser failure, had to replace entire system.
20,000 Miles - oil pump recall, handbreak issue where red warning light would intermittently come on.
25,000 Miles - Rattle in engine bay, shaft between transmission and transfer box, bushes/bearings faulty at end of universal shaft.
So shes currently back in the dealership as anther warranty issue.
Other than that, no , no problems Thumbs Up
Post #497535 28th Jan 2016 7:25pm
gtveloce65
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Epsom Green
I've had a wide range of faults, niggles, etc, since buying new in late 2008 - but in fairness, apart from a burnt out wiper motor, the vehicle's has always started and never stranded me (hopefully posting this will not alter things! Very Happy ) 1953 80
1965 Alfa Romeo GT Veloce Sprint
1980 Fiat 124 Spider
2008 110xs
Post #498128 29th Jan 2016 11:20pm
2hooky
United Kingdom 2013 Defender 110 Puma 2.2 DCPU Firenze Red
My 2013 DCPU has done 89500 miles and has had a new engine,gearbox,clutch,intercooler (old one split) and now in at the dealers for the 3rd week now with serious corrosion issues - the panel under the real seat is so badly corroded it has holes in it. Dealer stopped work on it now until LR approve the removal and replacement of this panel. I have a Disco Sport replacement and firslty is was the 2.2 engined one and I found that to be pretty gutless but that got replaced with a brand new 2 litre one - what a difference in performance. Overall its not a bad car but obviouslly isnt a real Disco 3/4 replacement.
Post #498827 31st Jan 2016 8:22pm
LoveB
2013 Defender 110 Puma 2.2 SW Orkney Grey
march 2013 delviered. now at 97,000KM
Post #499385 1st Feb 2016 10:44pm
