Home > Technical > Td5 injector codes
mk1collector
Td5 injector codes
having just got a nanocom I was looking through the menus and a question about injector codes came to mind. As injector codes need to be paired to the ecu if say the engine had had a head gasket done and the injectors were put back in the wrong order would this cause rough running or not running at all? As you can tell I'm board and have been stuck in the defender waiting for the eldest child for an hour Rolling with laughter Ray
My build thread
Post #496550 26th Jan 2016 10:59am
Martin
Site Admin
The injector codes are corrections for manufacturing tolerances, not a coding or key for security(?) or to prevent any other injector working.
The engine will run but injection timing and duration is not optimised, so there is potential for damage over an extended period.
The correct codes should be entered as soon as possible, or the injectors put back in the right order.
As you have Nanocom you have the ability to do the first Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #496553 26th Jan 2016 11:03am
mk1collector
Thanks for the info Thumbs Up there are nothing up with mine (hopefully) I was just curious Thumbs Up Ray
My build thread
Post #496555 26th Jan 2016 11:06am
Martin
Site Admin
Ah OK Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #496557 26th Jan 2016 11:09am
