![]() | Home > Technical > Td5 injector codes |
having just got a nanocom I was looking through the menus and a question about injector codes came to mind. As injector codes need to be paired to the ecu if say the engine had had a head gasket done and the injectors were put back in the wrong order would this cause rough running or not running at all? As you can tell I'm board and have been stuck in the defender waiting for the eldest child for an hour
![]() My build thread http://www.defender2.net/forum/topic17615.html |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6645 ![]() ![]() ![]() |
The injector codes are corrections for manufacturing tolerances, not a coding or key for security(?) or to prevent any other injector working.
The engine will run but injection timing and duration is not optimised, so there is potential for damage over an extended period. The correct codes should be entered as soon as possible, or the injectors put back in the right order. As you have Nanocom you have the ability to do the first ![]() ![]() ![]() |
Thanks for the info
![]() ![]() My build thread http://www.defender2.net/forum/topic17615.html |
Ah OK
