![]() | Home > Maintenance & Modifications > front number plate position |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5799 ![]() ![]() |
Sticky number plates are not legal any more, but most people are not bothered.
My number plate is on the front of my roof rack. Andy |
Mine was stolen
![]() Devon $x$ do brackets that fit behind the fairlead ![]() |
The self adhesive numbers are basicall illegaly. Otherwise it would render the legislation on number plates etc useless.
A couple of ideas for you. Take off the roller fairings or hawser and mount a couple of metal uprights Bolt your number plate to it using wing nuts. Chances are you will be off road when you are using your winch. Devon also do some which bumper number plate brackets. Look HERE HTH ![]() Brendan Looks like Ken beat me to it whilst I was typing |
Defender SVX Member Since: 29 Jan 2009 Location: Co Durham Posts: 730 ![]() ![]() ![]() |
![]() ![]() ![]() 16 Focus RS Nitrous Blue. 11 FFRR TDV8 Vouge SE Black Black. 08 DEFENDER SVX SOFT TOP (SUPERB) 08 DEFENDER 110 DCPU Stornoway grey (Overland Exploration Unit) 05 Fiesta ST 150 Van 04 Jaguar XKR 4.2 Supercharged V8 02 DEFENDER 90 TD5 (next years soft top project) 95 DEFENDER 110 CSW 300 TDi Phoenix black 95 DEFENDER 90 HT Monti Carlo blue COUNTY 300 TDi 67 109" SERIES 2a TUNED 200 TDI 64 DAVID BROWN 990 rat look 55 86" SERIES 1 |
lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 762 ![]() ![]() ![]() |
...our plates as the same size than yours ... more or less cm ...
I fitted mine here ... bolted to the bumper ![]() Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
Mike
Flat Dog, www.flatdoguk.com, do (or used to a couple of months ago) the G4 number plate holder. It is a flat plate, front number plate size, with two right angle brackets. Mine was £15. It is not shown on the website so give them a call if you want one. Bob |
cradgebank Member Since: 30 Dec 2008 Location: Nottingham Posts: 308 ![]() ![]() ![]() |
Just fixed mine to the Grill.
Never had any problems with air flow cooling in either summer or winter tempretures. Richard Either a 90, 110 or 130. Discovery 5 |
TACK Member Since: 26 Apr 2009 Location: Essex Posts: 1045 ![]() ![]() |
stuck mine to the sump guard under the bumper, look in my gallery
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
I have had mine on the vent flap for the past 18 months and never had any problems.... can't even see it now and still no problems
![]() Glyn ![]() |
If I remember correctly, as long as the reg number plaste is of appropriate type/spacing etc, the only requirements are that it is vertical and and is clearly seen to front or rear of vehicle. A bike on a rear bike carrier which obscures the rear number plate is illegal, hence need for a marker board
Brendan |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 981 ![]() ![]() |
Mine's cut down and on the off side of the winch bumper. I asked in the MOT centre about size and they said that there is a maximum but not a minimum.
See Gallery under Merlin’s photos. Merlin |
Lookers Park Royal Member Since: 19 Jun 2008 Location: London Posts: 338 ![]() ![]() |
I've got the D44 brackets on mine. Keeps some of the muck off the winch drum.
James ![]() |
