Home > Maintenance & Modifications > Mantec RAI Mounting
Bushpig
Wales 2012 Defender 110 Puma 2.2 SW Alpine White
Mantec RAI Mounting
My RAI was fitted by the dealers and the gap between the plastic and the bodywork is catching all sorts flora, some of which cannot be removed unless the RAI is removed.
I removed it last week, hoping that it had not been installed properly, but it all checked out 100%.
Can anyone confirm if this is indeed the case?
Does anyone else look like this?
 Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so.
Douglas Adams
2012 2.2 Puma
Post #494290 20th Jan 2016 5:08am
Terryt
It's fitted ok mate ..I used a bit of spare neoprene foam to make a small bung to stop the rubbish collecting
Terry
Post #494294 20th Jan 2016 5:25am
That's the way they are, one of the reasons why I went for a Safari amongst others.
The suggestion above should sort it out though in this instance.
Post #494327 20th Jan 2016 9:05am
mcma1
why i went for the older classic design as its a far better fit... Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #494383 20th Jan 2016 12:09pm
Bushpig
Thanks Terry for the idea of the foam, will add it to the 'to do' list...
If I'd known that is how it would fit, I would have gone for a different one...
Thanks all... Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so.
Douglas Adams
2012 2.2 Puma
Post #494454 20th Jan 2016 3:30pm
1978
United Kingdom 2003 Defender 90 Td5 HT Belize Green
I think Mantec probably had to design in an element of 'best fit' to compensate for Land Rover's 'tolerances' (or lack of!).
Post #494457 20th Jan 2016 3:45pm
YOLO110
Australia
Mine is the same.
THE most important part of the fit is a perfect watertight seal around the inlet 'hole' in the body. The rest is just aesthetic! Thumbs Up YOLO... You Only Live Once...
Post #494583 20th Jan 2016 9:50pm
camelman
To be honest, the mantec system isn't watertight so a perfect seal around the inlet hole won't stop the water getting sucked in further down the inlet pipework.
The only way to make it watertight is new pipework all the way to the airbox.....
Post #494585 20th Jan 2016 10:02pm
YOLO110
Australia
Agreed!
'Nugget Stuff' on 'AULRO' make a kit for just that :>) Thumbs Up But it needs to start with a proper seal around the RAI/body join of course! YOLO... You Only Live Once...
Post #494598 20th Jan 2016 10:35pm
camelman
That's next on my list of things to do when I get around to it Smile
Post #494604 20th Jan 2016 10:53pm
TJ101
Did mine just after Christmas & yes, that do stand proud of the wing
Another Mantec,, like all previous Puma Defenders, bar one, when that was fitted with a Safari
Do the job correct and Mantec work for me better, last one also done with the Nugget Stuff kit California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #494609 20th Jan 2016 11:09pm
camelman
How long did the Nugget kit take to fit?
Post #494657 21st Jan 2016 9:41am
TJ101
The whole job can be done in a hour and half
I took a tad longer, to line up with a post / door line etc,
Hardest bit was getting the old intake pipe out,, between the brake servo and inner wing,
Air hacksaw helped and where to cut !! Smile access via the wing top plate
Post #494673 21st Jan 2016 10:14am
Cheshire110
I'm planning to get a Mantec snorkel and nugget stuff kit.
On the nugget website they say 'check the air box' too or they cant guarantee watertight. What's the general consensus on the standard airbox? Cheers, David
Post #494786 21st Jan 2016 1:30pm
The airbox should be watertight, if clamped properly.
There is however a single drain hole in the bottom as you are probably aware.
Other than that it's airbox to ducting that is a non waterproof joint.
Then ducting to wing inner, then wing to RAI.
You do have to bear in mind however that Mantec's are a RAI and Safari's are Snorkels and as such RAI's are simply that not designed to be watertight.
However, I'm sure it can be done.
In my opinion you can seal both the nugget stuff kit and OE just the same but the benefit of the nugget stuff kit would be the reduced restriction of the OE ducting
Post #494838 21st Jan 2016 3:51pm
