![]() | Home > Maintenance & Modifications > Connection for Tuning Box |
Petronius4 Member Since: 07 Oct 2015 Location: Somerset Posts: 94 ![]() ![]() ![]() |
Afternoon all.
I have a Speedhawk Tuning box that I want to fit to my 90 TDCi (2015MY). Having just spent 30mins in the freezing cold having a hunt round its not immediately obvious where the box plugs in so I thought I'd save myself some hyperthermia time and ask. Anyone have a picture of where the connection is? Thanks ------------------------------- π²π» 1986 ex-Military 90 NAD 2.5 Soft Top. Sold π¬π§ 2015 Defender 90 - Ripon Landrover Heritage 006 |
![]() But, thought they only made 5 in total, and you say you have number 006. How many did they make in the end in total then? I remember their plan at the time was 2x90HT, 2x90SW, 1x110SW. Eric ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Open the panel below the steering wheel, 2x plastic flat head screws and you will find it
[quote="ericvv"]
![]() But, thought they only made 5 in total, and you say you have number 006. How many did they make in the end in total then? I remember their plan at the time was 2x90HT, 2x90SW, 1x110SW. Eric Eric, you're correct the original pan was to only make 5 and thats what I thought until I picked it up and they had put 006 on the back! There is someone from Ripon on here so maybe he'll know the quantity they finally produced. (i'm secretly hoping its only six...) This is mine... ![]() Click image to enlarge ------------------------------- π²π» 1986 ex-Military 90 NAD 2.5 Soft Top. Sold π¬π§ 2015 Defender 90 - Ripon Landrover Heritage 006 Last edited by Petronius4 on 18th Jan 2016 7:09pm. Edited 2 times in total |
Bpman: Thanks. Yes I've found that but the Speedhawk connects under the bonnet somewhere onto they injector loom - or leastways did when I had the box fitted to my Range Rover. Any ideas? -------------------------------
Bump -------------------------------
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2774 ![]() ![]() |
Yep they plug into the common rail, couldn't describe exactly where it is though but have done it.
However, it might not be what you want to hear, but the advice from most on here would be to steer well clear of these things. They are NOT a remap, but instead just a resistor which tricks the car into thinking it is putting less fuel in than it is (hence plugging straight into the common rail, not the ECU). There are stories galore of faults and failures caused by these things, admittedly as well as some stories where everything is fine. Proceed with caution. Cheers, David Land Rovers of all shapes S3 onwards⦠Daily is a 110 V8. |
I tried to find some info about this box. I didn't find much except that it manipulates airflow and fuelpressure data.
I don't like that. I have however also a tuning box a psi power box for my td5. This works different it send more fuel in the cylinder by keeping the injector longer open. I think that is better. A real remap can be better but I can switch it off and normally don't use it on-road only off-road. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 ![]() ![]() ![]() |
Tuning boxes are not good the ecu on a -2.2 needs a proper calabration not. Plug in box it will do more harm than good
All that thing will do is shirt more diesel in and pronounce any underlying problems the original calibration llready has Steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
If you want it tuned get a proper a remap. Steve.
