Home > Puma (Tdci) > Swapping Glow Plugs |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6298 |
it would be but I don't think there's any faults being logged. I don't think they record everything
17th Jan 2016 10:41am |
that was my intention but I'm not sure how possible / practical that is with the inlet manifold in place?
have you tried yourself or is that a theoretical suggestion? either way thanks for the comment. |
17th Jan 2016 10:53am |
Have you seen the number of different dtcs there are for the glow plug system in total? I think a scan tool will get you the answer you are looking for without even having to open the bonnet. |
17th Jan 2016 12:23pm |
martinfiattech Member Since: 13 Nov 2013 Location: leicester Posts: 422 |
Why not check for current draw thru the circuit. about 60 amps total from stone cold. =15 amps per glow plug.
Once they`ve been used they drop to 40 amps (ish) 8 to 10 amps. As long as there 12 volt ones. some run at 3.5 volts now, but that's mostly cars. Excuse the spelling I`am better with spanners and wires. |
17th Jan 2016 9:15pm |
long nosed plis you can remove the connector |
17th Jan 2016 9:23pm |
double post
17th Jan 2016 9:24pm |
Long nose pliers next week then.
17th Jan 2016 9:53pm |
