![]() | Home > Maintenance & Modifications > Plastic headlight cover/protector |
Land Rover Part Number: STC7561. Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
I've got some on mine because with having led headlights that run cold, snow can build up in winter and I though the covers would stop this happening. Two things I have found are, muck and water can get down behind them which makes them look terrible so I put a thin line of closed cell foam around the edge to stop anything getting down the back but when it gets cold now the covers fog up which is annoying. This shouldn't be a problem in summer but it's not so good in winter
![]() ![]() Click image to enlarge Ray My build thread http://www.defender2.net/forum/topic17615.html Last edited by mk1collector on 17th Jan 2016 7:21pm. Edited 1 time in total |
They will protect but the inside face will also get dirty fairly regularly and so to clean you will need to factor in taking them off and putting them back on again.
Sadi Member Since: 23 Jul 2015 Location: Windhoek Posts: 334 ![]() ![]() ![]() |
3M VPS or a clear window "smash & grab" film on the outer lens will also provide excellent protection - without issues of removing and cleaning.
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2725 ![]() ![]() |
Is it really a problem that needs to be solved?
I can't say I've heard of large numbers of Defenders suffering with smashed headlamps driving around the UK, or even further afield. Unless you're bashing through jungles or following trucks on gravel roads for hundreds of miles are they really at risk? The plastic lamps such as the Wipac Crystals or the LED offerings are probably more resistant to smashing than the glass ones anyway. |
As said above, my reason for having them is to keep snow off the lights in winter
![]() My build thread http://www.defender2.net/forum/topic17615.html |
jbk Member Since: 22 Nov 2015 Location: Hertfordshire Posts: 181 ![]() ![]() ![]() |
Thanks for the info guys, nice looks good 'Mk1collector'.
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4801 ![]() ![]() ![]() |
I've had a headlight smash before I changed to led. The stone was still inside, it happened within a 10mile stretch of my home ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
JAY BOY Member Since: 04 May 2010 Location: Not here Posts: 1706 ![]() ![]() |
James
Have you got your car yet ![]() |
