Home > Camping, Caravanning and Holidays > Nato socket to 7 pin converter? is there such a thing |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17466 |
You'll nly need to change the bulbs if the trailer is 24Volt.
There is no COTS adaptor available to or from the NATO 12-pin set up, because the people who use NATO sockets don't use civilian equipment. You could obtain the NATO socket from the back of a military vehicle and wire it onto one end of a lead with a seven pin 12N plug (or 13 pin, whatever you need) on the other, but it is going to be far less convenient that simpy fitting a normal lead to the trailer. Realistically, when are you going to want to use a NATO 12-pin connector on your trailer? Unless you own an ex-military LR, it is functionally useless! My advice is to remove the complete 12-pin plug and lead, replace it with a 7-pin plug and lead, and keep the NATO lead you have removed in case one day you do want to restore the trailer to as-built condition. |
15th Jan 2016 4:15pm |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3760 |
Good call to be honest and your right,
I'm unlikely ever to need the 24V Nato plug. So just store it. Is it a straight forward job to wire in the 7 pin socket as I would like the front lights and rear fog to actually work, Thanks |
15th Jan 2016 7:52pm |
http://www.towingandtrailers.com/technical...agram.html |
15th Jan 2016 8:11pm |
NATO PLUG
A & H: Spare B: Left hand stop C: Convoy D & L: Earth E: Tail and number plate F: Fog lamps J: Right hand stop light K: Aux positive M: Left indicator N: Right indicator Now convert to a 7 pin Yellow 1 to M left hand indicator Blue 2 to F fog lights White 3 to D earth Green 4 to N right hand indicator Brown 5 to E tail and number plate light Red 6 to B & J left hand stop & right hand stop Black 7 to E tail and number plate light |
15th Jan 2016 10:26pm |
Many thanks doe the 7 pin not have a Fog light? Thanks again very useful |
16th Jan 2016 7:14pm |
Yes, Pin 2 as noted in my post above.
The 12N pin allocations are as follows, with the colours used in 7-core trailer wire: 1 - Indicator Left (Yellow) 2 - Rear fog light (Blue) 3 - Earth (White) 4 - Indicator Right (Green) 5 - Offside side, marker & number plate light (Brown) 6 - Brake lights (Red 7 - Nearside side, marker & number plate light (Black) |
18th Jan 2016 8:33am |
My Bad,
Sorry I didn't read it correctly... |
18th Jan 2016 8:58am |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1630 |
heres one we made earlier
Click image to enlarge |
10th Jun 2019 6:51pm |
