Home > In Car Electronics > Temporary CB aerial mount?
dantastic
I need to use a CB radio in my Defender for a 2 week trip. I won't need it permanently so I don't want to drill any holes!
I have looked at the gutter mounts but they seem to be damaging the softer, rubbery compound in the gutter channel.
I was thinking, What if I attach the aerial to a suction mount? I know I need to use an artificial ground plane but apart from that, will the suction mount be string enough? I'm thinking one of these
http://www.ram-mount.co.uk/heavy-duty-suct...8_446.html
Or are there better methods of mounting CB aerials which doesn't involve any damage?
Post #491361 12th Jan 2016 10:54am
Stick a magmount on your bumper?
Post #491362 12th Jan 2016 10:56am
stanley
If you have a roof rack or bars then a clamp like this will do
Or fabricate a bracket to go behind the rear door hinge
Post #491363 12th Jan 2016 11:01am
dantastic
I don't have a roof rack - would have been too easy! Very Happy
Mag mount on the bumper won't be good. The aerial will just be bouncing off the bodywork.
I like the bracket for the rear door hinge. Nice solution.
Post #491368 12th Jan 2016 11:07am
Inigo
United Kingdom 2012 Defender 110 Puma 2.2 USW Orkney Grey
I used a gutter mount from 4x4CB:
http://www.4x4cb.com/public/item.cfm?itemID=1749
Works well, but where I have poked the cable underneath the seal for the second row doors it leaks a bit in heavy rain, but ok for temporary use.
Post #491374 12th Jan 2016 11:21am
dnorrishill
England 2014 Defender 90 Puma 2.2 XS CSW Aintree Green
If you have Puma Defender you have a steel bonnet - ideal for mag mount ariel - that's where mine is going!!
Post #491395 12th Jan 2016 1:04pm
Ranger
United Kingdom 2003 Defender 110 Td5 G4 LE Zambezi Silver
Or use a Midland handheld, plugs into your cigarette lighter socket and is good for 3-5 Km
http://www.thunderpole.co.uk/handheld-cbs/midland-42.html
Post #491456 12th Jan 2016 5:23pm
Devon-Rover
I knocked up a bracket to mount on the back door top hinge. Used a offcut of stainless and bent and drilled to shape. I might get round to making more when I get 5 minutes and the weather improves Rolling Eyes
Post #491504 12th Jan 2016 7:28pm
dantastic
Do let us know if you find yourself with a surplus mount you want to sell Wink
Post #491560 12th Jan 2016 8:56pm
