Home > Maintenance & Modifications > removing dashboard |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17207 |
There are threads on this forum covering this job, but it is not for the faint-hearted. On a 2.4 (which I imagine in very similar to a 2.2) it essential entails:-
Remove the radio Remove the centre panel (the one the radio fits in) Remove the steering wheel Remove the steering column shroud Remove the stalk switches from the steering column Remove the gear levers Remove the instrument panel Remove the side window demister outlets Remove the front speakers Remove the complete dash panel. Installation is the reverse of the ddismantling procedure. To remove and refit the entire dash panel is about 1 man-day in labour. |
1st Jul 2015 12:36pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10376 |
Hi, it's pretty straight forward, every torx head you see, undo it, remove the centre panel first and work your way either side...
I did this on my friends Puma a few years back.. Here's the only photo's I have left. Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
1st Jul 2015 12:37pm |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6677 |
As above, it's really easy to take the dash out, 30 mins tops
1st Jul 2015 1:52pm |
Snowy90 Member Since: 23 Feb 2015 Location: Surrey Posts: 482 |
Funny enough when its this hot my mind always wanders to retro fitting AC so will watch this with interest, Jools be good to see how you get on and photo's please
1st Jul 2015 2:17pm |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1232 |
Just make sure you make a note of which screws/bolts go where. Nothing worse than sitting back enjoying what you have accomplished only to find you have a bolt left over!
1st Jul 2015 3:04pm |
Barney12 Member Since: 09 Jun 2015 Location: South West Posts: 744 |
Surely what you meant to add was.... .....and whilst it's out get it trimmed in leather |
1st Jul 2015 3:50pm |
Joolz Member Since: 01 Jul 2015 Location: London Posts: 4 |
Thanks all - has given me confidence to tackle this later this month once parts arrive - will keep you informed -
J |
1st Jul 2015 6:57pm |
Quite right |
1st Jul 2015 6:59pm |
w12leo Member Since: 05 Oct 2015 Location: Farnham Posts: 85 |
has anyone got a picture of the dash removed head on?
i want to see what can actually get sound proofed? Wanting another 💠|
11th Jan 2016 8:45pm |
We have one in later this week, I'll grab some pictures.
There's very very little you could sound proof and I very much doubt it would make any difference if you did |
11th Jan 2016 8:57pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20115 |
Does anyone know how the insulation is held onto the bulkhead. (The grey soft foamy insulation.) ? Wondering due to Dynamat installing |
11th Jan 2016 9:38pm |
