Home > Maintenance & Modifications > What should a 10 year old chassis look like under normal con
Chamois
2002 Defender 110 Td5 CSW Zambezi Silver
What should a 10 year old chassis look like under normal conditions?
I imagine if it's been well looked after, wax oiled etc then it should look pretty good.
Any thoughts? or images?
Thanks Winter's here, thanks goodness!
Post #491095 11th Jan 2016 5:35pm
mse
thats a loaded question with so many factors.
Basically and potentially like new Mike
Post #491109 11th Jan 2016 5:54pm
Chamois
Ok what about this chassis? Personally it looks to me like it's been in the sea?
Post #491116 11th Jan 2016 6:03pm
mse
Thats not too bad, but not great either - have you seen other examples of similar ages. Mike
Post #491117 11th Jan 2016 6:11pm
Cheshire110
That looks fairly poor to me....
Our series 3 (1983) is a huge amount better.
If it looks like that on the rails then it could be much worse on outrigger, bulkhead, rear crossmember etc. But then again it could be solid and just surface rust.
Investigate thoroughly! Cheers, David
Post #491119 11th Jan 2016 6:14pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
That is a lot worse than my 03. I looked at a few and the difference is stark between some. 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #491120 11th Jan 2016 6:15pm
Chamois
Just trying to get a handle on what's good or bad, I've not looked at many.
Looks like it needs some work.
It's from an older car more like 14years old so maybe it's not so bad. Front looks much better though? Winter's here, thanks goodness!
Post #491121 11th Jan 2016 6:16pm
gazman
I know it's a picture of my exhaust rotten through, but you can make out the chassis behind it
Post #491122 11th Jan 2016 6:18pm
Cheshire110
problem is when it gets to a state as bad as that, it'll need work forever and you'll never have confidence in it.
It should definitely be mostly black!
And remember it'll be much worse inside than out. Cheers, David
Post #491123 11th Jan 2016 6:21pm
Chamois
Yes, that looks a lot better to me! Winter's here, thanks goodness!
Post #491125 11th Jan 2016 6:23pm
mse
I agree its not great, as i said above and it could be worse in other places or not.
Ive seen much worse TD5's on a 2005/2006 plate though.
Ive seen much better than some 3yr old ones too - depending on the love invested from the start Mike
Post #491143 11th Jan 2016 6:56pm
mikeh501
unloved. keep looking.
Post #491176 11th Jan 2016 7:51pm
Mo Murphy
Remember that chassis rust from the inside out. The outside appearance, whilst giving the impression of care, may not be truly indicative of the chassis condition.
A good looking 10 year old chassis might have been launching boats into the sea for the first 9 years of its life then cleaned and waxoyled last year. The waxoyl being thicker than the chassis metal that's left.
In that respect the photos tell you nothing, you need to get under it with your hammer and check it thoroughly, that's the only test.
I'd trust the rusty chassis first, at least I can see what I'm looking at.
Just my tuppence worth Smile
50 Shades of Pennine Grey
Post #491283 11th Jan 2016 11:27pm
HossBog
Here's mine (taken in July) - Sept 01...
 2002MY Defender 90 H/T
Post #492850 16th Jan 2016 8:21am
familymad
Looks like a Scottish vehicle...... far more salt exposed. 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #492914 16th Jan 2016 12:01pm
