![]() | Home > Technical > Clutch pedal assist kit |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1876 ![]() ![]() |
Does anyone have any experience of using or fitting one these
http://www.paddockspares.com/clutch-pedal-...ender.html the pedal is quite heavy in my 200 and I thought it might be worth a try and maybe not too difficult to fit? Rob 1993 200tdi 90 hard-top 1998 300tdi 90 soft-top 2016 2.2 XS 90 hard-top (sold) |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6642 ![]() ![]() ![]() |
I think on a 200 Tdi you will need a complete Td5/Puma pedal as the spring kit does not fit the earlier pedal.
I might be wrong though! ![]() I have changed the soft top's pedal assembly, it was originally a TD. ![]() ![]() |
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2025 ![]() ![]() |
I did it on my TD5 and the main hard part was removing the moulded floor covering as it is so stiff.
As Martin says, you'll need to check if it's even something you can do on a 200Tdi. 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
The clutch pedal assembly was not badly priced as a new part last year, it's tripled in price since then
![]() You'll probably pick up a second hand one OK. ![]() ![]() |
hmmm I'm glad I asked. The Paddocks description says it will fit all 90's however I've found an ebay listing for the genuine part number which says will only fit late 200tdi onwards from VIN LA939892 and mine is LA931*** so I'm assuming it won't fit
![]() Thanks for the advice guys Rob 1993 200tdi 90 hard-top 1998 300tdi 90 soft-top 2016 2.2 XS 90 hard-top (sold) |
