Home > Puma (Tdci) > Can't lock the diff |
Mash Member Since: 09 Feb 2015 Location: Guernsey Posts: 1674 |
You can get to it from underneath, there are a selection of rods/linkage on the r/h of the gearbox/tbox. Make sure they are not seized due to mud etc and ensure they are all connected, often the linkage snaps when forced. If you struggle to get to them you can remove the gearbox tunnel to get access. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
11th Jan 2016 2:08pm |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2024 |
Cake, have tried transferbox lever in the middle neutral position before pushing it to the left and forward to engage low range or left and backward to engage high range Difflock? See if you have any luck this way. Rather than straight across the box.
11th Jan 2016 2:21pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17202 |
^^^ Why?
You don't need (and don't want) to do this! |
11th Jan 2016 2:25pm |
Cake Member Since: 10 Jun 2015 Location: Essex Posts: 277 |
Daz110 I think you have it, I'm putting it in low and then trying to go left!
It's so simple when you know how! I do feel quite stupid asking these questions but its all new to me. I will try this evening and report back! Mash - Thanks, if it doesn't work the 'proper' way then I will take a look underneath - I will take a look anyways to ensure everything is clean and as it should be now I know. |
11th Jan 2016 2:27pm |
What your doing should work ok that way.
As Mash says probably seized. |
11th Jan 2016 2:43pm |
The difflock should be operable irrespective of whether you're in low box, neutral, or high box. The two mechanisms are independent.
11th Jan 2016 4:05pm |
Is it actually going into difflock but the light on the dash is not coming on?
11th Jan 2016 4:12pm |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1826 |
^^^ On mine, it can take a good few yards before the diff lock light comes on. I guess the gears need to align before it fully engages and hence you sometimes need to travel (100yds should be more than plenty) to get it engaged.
Other options as discussed are seized linkage. There is a very small/fragile looking link at the bottom of the lever from the cab, where it connects to the diff lock arm from the transfer box. This is the bit that seized on mine. Needed a good amount of WD40 to free it up, then I covered it in copper grease. Has been fine for the last few years, but then it gets used a lot these days... Good luck. cheers simon |
11th Jan 2016 5:40pm |
When I push left its doesn't move and quite a bit of resistance is there.
I have read about others breaking so I'm not not pushing too hard but definately enough for to engage if it would. I will try engaging from neutral and have a look underneath (despite not knowing exactly what I'm looking for) - I assume it's mounted somewhere between the prop shafts and gearbox... Will report back this evening |
11th Jan 2016 6:37pm |
Click image to enlarge Here you go. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
11th Jan 2016 6:42pm |
Thank you so much!
Now I'm ready to give it all a go |
11th Jan 2016 6:52pm |
I just took this underneath mine but the above picture is clearer...!
Anyway, the little link I circled in red is the one that seized on mine. Click image to enlarge |
11th Jan 2016 6:57pm |
Thank you so much for the effort - will take a look shortly
11th Jan 2016 7:35pm |
So finally it's been fixed!
The area circles was the culprit was the circled area I put some WD40 on which made no difference at all. Then some some PlusGas which instantly released it. It engages and releases no problem - the light is instant too! Thank you all for the help and effort! I feel I will be ready for my next bit of off roading now |
11th Jan 2016 8:30pm |
