Home > Technical > Rover v8 distributor |
Iggle piggle Member Since: 10 Sep 2014 Location: Wales Posts: 378 |
Im fairly sure it doesn't matter what make coil you use, but stand to be corrected if wrong,
Give Powerspark a call, I replaced all the ignition parts on my v8 and found them very helpful http://www.simonbbc.com |
6th Jan 2016 10:09pm |
charcoal Member Since: 28 Jul 2014 Location: Hampshire Posts: 942 |
Many thanks, I'll give them a ring tomorrow! 1999 Land Rover Defender 110 td5 station wagon
1998 Land Rover Defender 110 County Station Wagon ~ Sold 1995 Land Rover Defender 110 V8 Station Wagon ~ Sold 1985 Land Rover 110 ex mod project Tithonus ~ Sold |
6th Jan 2016 10:58pm |
jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1790 |
Hi Charcoal
The old RPi website has a lot of information which will help you identify the distributor in your engine and also give guidance on easy upgrades to the ignition system http://www.v8engines.com/electrics-1.htm Cheers John 2014 110 2.2TDCi XS Station wagon 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - Gone 2024 110 D250 X-Dynamic HSE |
6th Jan 2016 11:45pm |
Thanks for the link John, looks like I have a 35DLM8! 1999 Land Rover Defender 110 td5 station wagon
7th Jan 2016 11:47am |
MR_JAMES Member Since: 10 Oct 2013 Location: ESSEX Posts: 248 |
thats the dizzy with the ignition module bolted to the side of it? from memory you only need a balast resistor with the points setup.. which reduced the voltage a bit..
the electronic ignition type runs on normal 12volts. this comes from my mini days similar setup. 1953 80" 1987 mini city e 2011 90" |
7th Jan 2016 9:52pm |
Natlas Member Since: 20 Mar 2013 Location: West Sussex Posts: 460 |
Might be worth looking up the Distributor Doctor on the internet, he seems to have knowledge and parts for this sort of thing.
www.distributordoctor.com Cheers. 2.2 90 XS 88" Series One Old Norton Minerva |
7th Jan 2016 10:02pm |
Thanks for the help everybody, just bought myself a Lucas ignition coil (to be on the safe side) and a ballast resistor. When I finally find an engine crane I'll get the engine onto a stand, wire it up and see if it all works. 1999 Land Rover Defender 110 td5 station wagon
9th Jan 2016 11:21pm |
