Home > Technical > Rover v8 distributor
charcoal
United Kingdom 2005 Defender 110 Td5 HT Bonatti Grey
I am looking to get an ignition coil for my Rover v8. I don't know the manufacturer of the distributor and read on another forum that Lucas and Bosch ignition parts are incompatible with each other, is this true? I have a Lucas ignition module on the side of the distributor so does this mean it'll be a Lucas distributor too? While we are on the subject of v8 ignition systems should I also get a ballast resistor for the ignition coil? 1999 Land Rover Defender 110 td5 station wagon
1998 Land Rover Defender 110 County Station Wagon ~ Sold
1995 Land Rover Defender 110 V8 Station Wagon ~ Sold Sad
1985 Land Rover 110 ex mod project Tithonus ~ Sold Sad
Post #489306 6th Jan 2016 7:02pm
Iggle piggle
United Kingdom 1989 Defender 90 V8 Petrol ST Alpine White
Im fairly sure it doesn't matter what make coil you use, but stand to be corrected if wrong,
Give Powerspark a call, I replaced all the ignition parts on my v8 and found them very helpful
http://www.simonbbc.com
Post #489387 6th Jan 2016 10:09pm
charcoal
Many thanks, I'll give them a ring tomorrow! 1999 Land Rover Defender 110 td5 station wagon
Post #489413 6th Jan 2016 10:58pm
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
Hi Charcoal
The old RPi website has a lot of information which will help you identify the distributor in your engine and also give guidance on easy upgrades to the ignition system
http://www.v8engines.com/electrics-1.htm
John Thumbs Up 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 D250 XS Edition - Gone
2024 110 D250 X-Dynamic HSE
Post #489426 6th Jan 2016 11:45pm
charcoal
Thanks for the link John, looks like I have a 35DLM8! 1999 Land Rover Defender 110 td5 station wagon
Post #489560 7th Jan 2016 11:47am
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
thats the dizzy with the ignition module bolted to the side of it? from memory you only need a balast resistor with the points setup.. which reduced the voltage a bit..
the electronic ignition type runs on normal 12volts.
this comes from my mini days Smile similar setup. 1953 80"
1987 mini city e
2011 90"
Post #489772 7th Jan 2016 9:52pm
Natlas
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Aintree Green
Might be worth looking up the Distributor Doctor on the internet, he seems to have knowledge and parts for this sort of thing.
www.distributordoctor.com
Cheers. 2.2 90 XS
88" Series One
Old Norton Smile
Minerva
Post #489779 7th Jan 2016 10:02pm
charcoal
Thanks for the help everybody, just bought myself a Lucas ignition coil (to be on the safe side) and a ballast resistor. When I finally find an engine crane I'll get the engine onto a stand, wire it up and see if it all works. 1999 Land Rover Defender 110 td5 station wagon
Post #490481 9th Jan 2016 11:21pm
