Home > Td5 > Td5 anti roll bar |
chinnus Member Since: 24 Aug 2012 Location: UK Posts: 119 |
Hi there,
My td5 pickup 2001 didn't come with front or rear anti roll bars I have found all the parts numbers apart from the following.... The bracket that mounts the bar onto the fuel tank and the bolts and nuts associated with it? The front arb chassis to bar bracket and the nuts and bolts that go with that I believe 4 bolts in all? Many thanks in advance and merry xmas to everyone Tom |
25th Dec 2015 10:39am |
Hi there, thanks for your reply.
Rear On my neighbours 2.2 the rear arb mounts onto the fuel tank guard/surround with a D shaped bracket? Kind regards Tom |
25th Dec 2015 11:08am |
Justtellme Member Since: 23 Nov 2015 Location: Ottawa Posts: 310 |
That doesn't sound like a correct installation, but I'm not familiar with the late models...normally the D bushings on Defenders and pretty much every car I'm familiar with are attached to a solid point on each of the chassis rails. Perhaps your mate has an aftermarket tank protector which also utilizes the rear ARB bracket mounts concurrently?
The drop links are then attached to a dynamic suspension component, normally as far outboard as possible for max leverage....depending on thickness of the bar and how much roll you wish to contain. I know my TD5 has all the D bracket mounts welded to the chassis, front and rear In case one wishes to install. Cheers Patrick |
25th Dec 2015 12:23pm |
Will take some pictures later
25th Dec 2015 1:11pm |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 559 |
Your right the arb's mount using D shaped brackets underneath the fuel tank, this is for a 90, on a 110 there is brackets on the chassis.
Regards Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
25th Dec 2015 5:54pm |
Gav40 Member Since: 30 May 2015 Location: Maidstone Posts: 41 |
Hi, just done this mod on my TD5 and the rear brackets and bushes are smaller than the front ones and are availible from island 4x4 and mount into the rear chassis rails adjacent to the fuel tank, I just used some normal m8 bolts that I had to mount them. Pre TD5 rear anti roll bars used the same larger brackets as used on the front for the rear as well bar the smaller bushes. That as I understand it anyway.
25th Dec 2015 5:58pm |
Hi there I have go the pictures now.... I forgot to mention I am talking about a 90
This is where the ARB mounts on a 2.2 on the fuel tank bracket Click image to enlarge This is what the bracket looks like on my TD5 minus the bracket and the ARB... My question is what is the part number of said bracket and would it reuse the existing bolts? Click image to enlarge Thank you in advance |
8th Jan 2016 4:56pm |
Hi, yes mine mounts onto the fuel tank surround the same as your first photo, I didn't explain very well in my previous reply!
The only part number I can find is a britpart one and is the same brackets that I used when I did mine and bolts to the same place. Don't know if you can use the existing bolts you have but worth a try |
9th Jan 2016 7:53am |
Click image to enlarge |
9th Jan 2016 7:56am |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 |
Fitted anti roll bars to my 90 td5 today as it never had them from factory took me about 1&1/2 easy to do and has made a huge difference 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
9th Jan 2016 6:29pm |
Thank you to everyone for their input on this thread... For refrence I have attached the part numbers I used to buy all the bits for my 90 2001 TD5 and the prices I paid...
Ball Joint for Anti-Roll Bar - For Defender, Discovery and Classic NTC1888 4 18.00 Washer for Anti-Roll Bar Pin - Defender, Discovery RYF500160 4 1.92 Pin / Bolt for Anti-Roll For Defender - Goes Through NTC1888 Ball Joint RYG501480 4 4.80 Washer for Anti-Roll Bar Ball Joint - Defender, Discovery WC116101 2 1.26 Nyloc M16 Nut for Anti-Roll Bar Pin and Diff Flange - Defender, Discovery, Classic (Comes as Single Nut) NY116041L 4 1.96 Defender Anti-Roll Bar Clamp, Also Fits Discovery 1 NTC6776 2 10.00 Rear Bush chassisx2 EGP1889 Front Bush chassis x2 NTC6828 Drop link bush x8 552819 LR DIRECT - best price Front 4 bolts SH110351L , washer WA110061L and Nyloc NY110047L Rear 4 bolts washer and Nyloc - still finding part numbers cheers |
11th Jan 2016 10:15am |
