Home > Td5 > Td5 Wheel Bearing Replacement
Page 3 of 5 <12345>
ROBBONTHEROCK
Scotland 2007 Defender 110 Puma 2.4 XS CSW Firenze Red
Hi,
Point taken - I guess the only way to double check would be measure the end float.
Sigh, oh well, looks like i'll be buying and converting to the two nut system.
It doesn't mean a change to the hub carrier does it, just you need two nuts and new locking ring.
Andy
Post #487553 1st Jan 2016 4:10pm
JWL
No change, the only thing that's different is two thin 52mm nuts with a large things washer to bend over the flats as opposed to a large nut with a conical type top that can be flattened against the flat on the threaded part of the stub axle.
Post #487557 1st Jan 2016 4:26pm
rustandoil
ROBBONTHEROCK wrote:
I'm figuring the bearings are the same on both kits, if its the single nut set-up, then I will just re-use the spacer and rely on the bearing manufacturer tolerances.
At the end of the day, surely the spacer is not really for the bearing tolerence (they are manufactured to tight specs), but the machining tolerance of the hubs, so if you reuse the same hub then really you should be fine (I think).
Andy
That's how i was thinking, but in practice I needed to change the spacers
Post #487566 1st Jan 2016 4:57pm
ROBBONTHEROCK
Thanks for the advice folks.
Bearing kit(s) ordered from island 4x4, just need to get them on Wednesday to fit them.
Will let you know how i get on Smile
Andy
Post #487640 1st Jan 2016 8:42pm
Lionel
Australia
[quote="Appleby"
Quote:
After having my landy up on axle stands over the weekend I can feel absolutely no play in any of the bearings Smile I wouldn't put it past the garage that did the MOT to fishing for work (I wouldn't use them if they weren't so damn cheap).
IMHO if you can't detect any play in the bearings when the vehicle is on stands, I would leave them in. Any serious play will effect the brakes first, in my experience. You will notice that after going around corners the pedal travel will increase slightly when you press the brake.
Try this as a test, & if all is well just re-grease the bearings & leave them in - & of course, keep an eye on them.
Cheers,
Lionel
Post #488325 3rd Jan 2016 10:12pm
ROBBONTHEROCK
hi all,
Just removed the bearings on my truck, on the drivers side, will refit them tomorrow.
When fitting the hub seal on the rear of the hub, the workshop manual says fit the hub seal flush with the hub.
Looking at the existing hub seal, it looks like its sitting approx 3 to 4 mm deeper in the hub, with perhaps just the lip sitting flush.
Whats the correct setting, and is using the lr tool to fit the hub seal critical? I was figuring to just chap it into position using the old bearing race to the correct depth.
Thoughts?
Andy
Post #489826 8th Jan 2016 12:29am
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
Fit it flush as stated, it will get pushed in further if required on bolting up the hub Thumbs Up
Special tool not required, I tap them in with a small rubber mallet .... Just make sure you keep it straight .. Guns and Landrovers .... anything else is irrelevant.
Post #489873 8th Jan 2016 9:41am
ROBBONTHEROCK
Great, thanks.
At what point do you bother changing the hub shaft (the shaft the bearings sit on)?
I'm guessing it the seal surface is badly scarred or scratched, or on the surface shaft the bearing's sit on. I just want to know how bad I can leave it before changing it.
Also, anything I would need to watch if I were to replace the hub shaft.
The bolts are very rusty looking, so I guess there is a good chance of rounding them or snapping them?
I guess the trick there would be to heat the area of the threads on the diff side and then give it a go.
If you round the head off the bolts, then you grind back and weld a nut onto the bolts to go again??
I'm up for putting new kit on the rear axle, but am cautious on what additional work I create!!!
Andy
Post #489929 8th Jan 2016 12:20pm
yetiman45
England 2005 Defender 110 Td5 CSW Blenheim Silver
The stub axles do wear in time, the part where the axle meets the flange can become pitted and that then will cause wear on the oil seal wiper, so then you get leaks. The bolts are high tensile and will take a lot of torque before they break, just give them a good soak with WD40 etc.
Post #489935 8th Jan 2016 12:58pm
The hub seal should be fitted so that it is inset into the hub, and personally I wouldn't fit it flush and rely upon the fitting of the hub to push it in (if you do that the seal must by definition be rubbing on something it shouldn't rub on. The latest seats are double-faced anyway and therefore protrude outwards.
The easiest and cheapest special tool to use when fitting these is a standard drive flange. The face which usually bolts to the hub has a locating ring on it which is exactly the right diameter to fit the seal, and exactly the right thickness to inset the seal the right distance. So place the seal on the hub, place the drive flange carefully on the seal, and gently tap the seal evenly into place until the drive flange touches the hub all round. Job done.
I keep an old drive flange in the toolbox specifically as a hub seal fitting tool.
Post #489949 8th Jan 2016 1:55pm
Mo Murphy
That's a good tip Blackwolf !
Remember Gents, when greasing the bearings that you need to pack grease around the rollers not just wipe grease onto the bearing, so a good handful of grease in your hand and really push it in around rollers. It should take a few minutes to do each bearing.
Oh and rubber gloves are a good idea 😊
HTH
50 Shades of Pennine Grey
Post #489967 8th Jan 2016 3:40pm
ROBBONTHEROCK
Brilliant tip, I will look at doing this tomorrow, get the Landy back on the road Wink
Andy
Post #489978 8th Jan 2016 4:37pm
ROBBONTHEROCK
HTH
Mo
Yeah, I know what you mean on this one.
Need to ensure the grease works it's way into the rollers!
Andy
Post #489996 8th Jan 2016 5:10pm
ROBBONTHEROCK
Folks,
Regarding the driving flange trick to set the seal in place;
Do you press it in until the flange bottoms out on the hub?
Never used this trick before and i really want to avoid Censored the seal!!!!
New seal height (height of the lip) is 5.5mm.
Driving flange edge height is 6.75mm.
Old seal seems to set to around 4 to 3.5mm measured from hub edge to the body of the seal.
PS the driving flange is a new LR flange (not brit part).
Andy
Post #490087 8th Jan 2016 8:47pm
Yes.
Post #490127 8th Jan 2016 10:48pm
Page 3 of 5 <12345>
