Home > Td5 > Td5 Wheel Bearing Replacement |
ROBBONTHEROCK Member Since: 23 Jun 2014 Location: Aberdeenshire Posts: 637 |
Hi,
Point taken - I guess the only way to double check would be measure the end float. Sigh, oh well, looks like i'll be buying and converting to the two nut system. It doesn't mean a change to the hub carrier does it, just you need two nuts and new locking ring. Cheers Andy |
1st Jan 2016 4:10pm |
No change, the only thing that's different is two thin 52mm nuts with a large things washer to bend over the flats as opposed to a large nut with a conical type top that can be flattened against the flat on the threaded part of the stub axle.
1st Jan 2016 4:26pm |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 734 |
That's how i was thinking, but in practice I needed to change the spacers |
1st Jan 2016 4:57pm |
Thanks for the advice folks.
Bearing kit(s) ordered from island 4x4, just need to get them on Wednesday to fit them. Will let you know how i get on Cheers Andy |
1st Jan 2016 8:42pm |
hi all,
Just removed the bearings on my truck, on the drivers side, will refit them tomorrow. When fitting the hub seal on the rear of the hub, the workshop manual says fit the hub seal flush with the hub. Looking at the existing hub seal, it looks like its sitting approx 3 to 4 mm deeper in the hub, with perhaps just the lip sitting flush. Whats the correct setting, and is using the lr tool to fit the hub seal critical? I was figuring to just chap it into position using the old bearing race to the correct depth. Thoughts? Cheers Andy |
8th Jan 2016 12:29am |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 |
Fit it flush as stated, it will get pushed in further if required on bolting up the hub
Special tool not required, I tap them in with a small rubber mallet .... Just make sure you keep it straight .. Guns and Landrovers .... anything else is irrelevant. |
8th Jan 2016 9:41am |
Great, thanks.
At what point do you bother changing the hub shaft (the shaft the bearings sit on)? I'm guessing it the seal surface is badly scarred or scratched, or on the surface shaft the bearing's sit on. I just want to know how bad I can leave it before changing it. Also, anything I would need to watch if I were to replace the hub shaft. The bolts are very rusty looking, so I guess there is a good chance of rounding them or snapping them? I guess the trick there would be to heat the area of the threads on the diff side and then give it a go. If you round the head off the bolts, then you grind back and weld a nut onto the bolts to go again?? I'm up for putting new kit on the rear axle, but am cautious on what additional work I create!!! Cheers Andy |
8th Jan 2016 12:20pm |
yetiman45 Member Since: 22 Dec 2014 Location: Tamworth Posts: 69 |
The stub axles do wear in time, the part where the axle meets the flange can become pitted and that then will cause wear on the oil seal wiper, so then you get leaks. The bolts are high tensile and will take a lot of torque before they break, just give them a good soak with WD40 etc.
8th Jan 2016 12:58pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17308 |
The hub seal should be fitted so that it is inset into the hub, and personally I wouldn't fit it flush and rely upon the fitting of the hub to push it in (if you do that the seal must by definition be rubbing on something it shouldn't rub on. The latest seats are double-faced anyway and therefore protrude outwards. The easiest and cheapest special tool to use when fitting these is a standard drive flange. The face which usually bolts to the hub has a locating ring on it which is exactly the right diameter to fit the seal, and exactly the right thickness to inset the seal the right distance. So place the seal on the hub, place the drive flange carefully on the seal, and gently tap the seal evenly into place until the drive flange touches the hub all round. Job done. I keep an old drive flange in the toolbox specifically as a hub seal fitting tool. |
8th Jan 2016 1:55pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2211 |
That's a good tip Blackwolf !
Remember Gents, when greasing the bearings that you need to pack grease around the rollers not just wipe grease onto the bearing, so a good handful of grease in your hand and really push it in around rollers. It should take a few minutes to do each bearing. Oh and rubber gloves are a good idea 😊 HTH Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
8th Jan 2016 3:40pm |
Brilliant tip, I will look at doing this tomorrow, get the Landy back on the road Cheers Andy |
8th Jan 2016 4:37pm |
Yeah, I know what you mean on this one. Need to ensure the grease works it's way into the rollers! Cheers Andy |
8th Jan 2016 5:10pm |
Folks,
Regarding the driving flange trick to set the seal in place; Do you press it in until the flange bottoms out on the hub? Never used this trick before and i really want to avoid the seal!!!! New seal height (height of the lip) is 5.5mm. Driving flange edge height is 6.75mm. Old seal seems to set to around 4 to 3.5mm measured from hub edge to the body of the seal. PS the driving flange is a new LR flange (not brit part). Cheers Andy |
8th Jan 2016 8:47pm |
Yes. |
8th Jan 2016 10:48pm |
