Home > Maintenance & Modifications > Piston cleaning advice?
Hairy Beekeeper
United Kingdom 1990 Defender 130 200 Tdi HCPU Aintree Green
Here's a quick one,
before I start scraping and sanding, is there a better way of de-coking the pistons?
It's a 200tdi with the swirl chambers. Someone mentioned burning to me, I've seen it done to the exhaust manifold, but I think the heat may damage the ally.
I have a rebuild thread for those who are interested.
(can someone tell me how to find the link to it please?)
Cheers,
HB Currently rebuilding my stretched 110 (now 122) to personal spec, probably going to be a double cab dropside, but not fully decided yet. So I've started at the front end first!
http://www.defender2.net/forum/topic41658.html
"Sorry love, don't make me choose between you and my Lanny. You won't like the answer....."
Post #488410 4th Jan 2016 10:26am
jimbob7
Soda blasting if you have a compressor (Sand blasting with bicarbonate). Pov.spec,ftw. 2006, 110,TD5.
Post #488432 4th Jan 2016 11:18am
Bumpymike
United Kingdom 1992 Defender 90 200 Tdi SW Bronze Green
Soak in warm water with soap powder over night - even better if keep it moving with a bit of compressed air.
We use to use this method on large bore Diesel engines ( 900mm) and turbo charger rotors.
Post #488466 4th Jan 2016 1:30pm
alby
United Kingdom 2015 Defender 90 Puma 2.2 SW Santorini Black
^^^what he said, can confirm it works a treat. An industrial parts washer aka domestic dish washer works too!
Post #488476 4th Jan 2016 1:52pm
Daisy90
United Kingdom 2001 Defender 90 Td5 SW Alveston Red
Of your replacing the rings? Snap an old ring and it make s a great ring groove clearing tool Thumbs Up
Post #488536 4th Jan 2016 5:22pm
Hairy Beekeeper
Thanks guys, I tried this method and was surprised at the outcome.
I placed the pistons in a large pan of soda water on my burner in the workshop and they came up a treat!
Post #489545 7th Jan 2016 11:08am
