Home > Puma (Tdci) > Front recovery points
ChrisCM
United Kingdom 2010 Defender 110 Puma 2.4 SW Santorini Black
Hi,
I have read a lot of posts on here regarding what can be used as a recovery point. My vehicle, a 2010 110XS SW has these rings fitted, they are bolted through the chassis on the bolt which attaches the steering guard.
Are these recovery points? I cannot see any welded on tie down rings other posts have referred to.
Thanks,
Chris 2010 Defender 110 Station Wagon, Santorini Black.
Post #488780 5th Jan 2016 11:33am
mikeh501
they are tie down points intended for tranportation not for recovery. They will be fine for towing on road, but are not strong enough for off road recovery, especially if its very stuck in heavy mud etc.
Post #488783 5th Jan 2016 11:43am
ChrisCM
Hi Mike,
Thanks.
That being the case, what do you (or anyone else) think of these, seem very easy to fit and look quite smart (and expensive Confused ) ?
http://www.mudstuff.co.uk/recovery-eyes.html
Jate rings seem out of the question as the steering guard/tie downs have the holes, also it means scrabbling about underneath in the mud!
Post #488803 5th Jan 2016 12:53pm
mikeh501
it really all comes down to what you intend recovering Mr. Green
Those mudstuff ones will be fine with a bit of light recovery id guess, but the more load you intend putting on them, the more substantial you will want the recovery points to be. There is a thread in the general area on the same subject going on 3 pages. its all horses for courses tbh.
Generally the best recovery points are those which are made of substantial thickness of steel, and which have fixings onto multiple points on the chassis rails. So for the front you'd want something which is a good few mm thick steel, and which attaches to both chassis rails. i.e. a proper winch bumper. Now obviously that could be complete overkill for what your doing, hence my initial question Very Happy
Post #488824 5th Jan 2016 1:32pm
ChrisCM
Hi Mike,
I don't expect to be doing too much heavy recovery stuff but I have 10 acre smallholding so there is the usual mud and hauling stuff around. I would like to have a winch & bumper but can't really justify the cost! and I don't really envisage being up to the axles in mud.
The MUD ones attach using the 2 bumper bolts through the chassis (which is in good condition) so hopefully they would be strong enough? especially if I rig a bridle to both? 2010 Defender 110 Station Wagon, Santorini Black.
Post #488843 5th Jan 2016 2:18pm
leeds
There is a discussion here about straps and recovery points.
An alternative to the GMB ones are the Nakatanenga ones here
Brendan
Post #488943 5th Jan 2016 7:28pm
ChrisCM
Hi Brendan,
Thanks for that, they look very similar, I was about to order a rear door seal retaining strip from you so will add this to the order!
Post #489031 5th Jan 2016 10:56pm
scotsstag
Scotland 2004 Defender 90 Td5 CSW Rutland Red
They are predominantly towing eyes for on-road recovery but they are ALSO to be used for lashing/tie downs points.
As stated in the user manual. 04' 90 Td5 CSW..
Post #490493 9th Jan 2016 11:56pm
ChrisCM
Hi Guys,
Received the recovery eyes, Thanks Brendan, will fit them when the rain stops and and take some photos.
Post #490498 10th Jan 2016 12:26am
Keith5
United Kingdom 2012 Defender 110 Puma 2.2 USW Santorini Black
I'm looking to find an option for putting a front recovery point onto my 110, The eye's here look ideal (given that the other option I'm considering is mounted on a steering guard).
My issue is that I have, and quite like, the soft A Bar on the front so cant mount these eyes.
Are there any other suggestions for front recovery points that people can suggest. While I'm thinking of fitting a steering guard I don't really want to be trying to hook onto anchor points on it when its in the mud.
Thanks Keith
Post #691849 7th Mar 2018 10:47pm
BogMonster
Falkland Islands 2015 Defender 110 Puma 2.2 USW Corris Grey
If you have a standard bumper fitted at the moment, you could swap that for the military type bumper with the towing pin in the middle. It's quite a neat solution and readily accessible.
Black type: https://www.johncraddockltd.co.uk/other/mi...w-jaw.html
Galvanised: https://www.firstfour.co.uk/defender-galva...umper.html
Either will need a pin purchased separately.
First Four also do a heavy duty front bumper with a 2" receiver socket on it but it is quite expensive just to get a front towing point! ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi
Post #692451 10th Mar 2018 5:02pm
discomog
I have the Nakatanenga ones from Brendan, easy to install and look good without being too obtrusive.
 Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #692462 10th Mar 2018 6:01pm
