Home > Maintenance & Modifications > What's next for 2016?
Page 3 of 3 <123
Hufflepuff
And me. That looks like a much better place to put the underseat relays, is that what it actually is?
Post #488164 3rd Jan 2016 2:33pm
ericvv
It is indeed a amended seat box housing all the relays and fuses for everything installed after market, so nothing to do with the original factory electrics. Clean solution, good access, easy to label as required.
I will have this installed after the winter to clean up my under bonnet relays, fuses and wiring spaghetti for the fogs, DRL, etc. Location of these relays inside the cabin with easy access is going to be much better than under the bonnet.
Once it is all installed in its final configuration, I will happily provide more info. Thumbs Up
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #488216 3rd Jan 2016 5:21pm
Page 3 of 3 <123
