Home > Off Topic > Pressure washers
Page 1 of 4 1234>
DefenderOfTheEarth
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
Pressure washers
My previously excellent Halfords HP2800 (125 bar) pressure washer has broken and I'm not sure I want to spend �40+ getting it "fixed" when I can see the place it broke it not well made - a shame as most of it is made from very solid brass/metal and it works well.
Any recommended brands?
Needs to be at least 125 bar and electric. Thinking �200ish and don't want a cheapo job - my damn BMW wheels needs serious power to blast all the dirt off - otherwise it's a very long job by hand. Of course I also need to be able to keep the Landy clean.
Anyone know about Sealey, Makita or any others? Defender 110XS SW gone... now VW California 180 4 Motion.
Post #48565 14th Dec 2010 7:37pm
mick
I got a karcher k5.68 20-140 bar and its very good. Got it from cosco.
Post #48566 14th Dec 2010 7:43pm
DefenderOfTheEarth
Mick - how long have you had it? I want something that lasts well.
Heard a few horror stories about Karchers but it might just be their low rent models. Defender 110XS SW gone... now VW California 180 4 Motion.
Post #48567 14th Dec 2010 7:45pm
mick
Over 12 month but if you get one from cosco you seem to get an unlimited warranty if you keep your receipt
Post #48568 14th Dec 2010 7:59pm
TC
Nilfisk are excellent. If you have a search for car detailing forums you will find stacks of info.
I had a Karcher, it died a death after 3 months of only light use. Replaced it with a Nilfisk over 18 months ago, never missed a beat.
The one I bought was one up from base http://www.amazon.co.uk/Nilfisk-X-Tra-Pres...t_edpp_url
It will run for extended periods, I did a mammoth driveway moss clearance at the start of the summer that took a good 6 hours. For its cost and size it is very powerful. The only thing I would say is that the bottle attachement is crap, another �50 will get you a very good quality snow foam lance - highly recommended for cleaning the Landy, snow foam treatment in advance of a wash will allow the bulk of the muck to drip onto your drive before you so much as touch it with a cloth or sponge.
Post #48569 14th Dec 2010 8:12pm
Laurie
I've had one Karcher pack up in four hours and another 'industrial' size one that gave up in two years.
They're excellent when they work but try to find a company to repair one.
Karcher never answer emails.
Post #48598 14th Dec 2010 11:19pm
landyman1
United Kingdom 2009 Defender 110 Puma 2.4 USW Stornoway Grey
Very Happy For serious heavy duty work and indestructible try kranzle pressure washers.
commercial range with brass valves and stainless steel seats in the pump, not the usual plastic.10 year warrantee on key components. will go on forever but AT A PRICE . may not be what you want to spend but you'll never have to buy another one.
Thumbs Up 1981 series 3 swb gone
1986 v8 110 station wagon current
2009 puma 110 xs utility station wagon latest addition
Post #48603 15th Dec 2010 12:11am
DefenderOfTheEarth
They look great but start at over �400 for the 115 bar model... Shocked Defender 110XS SW gone... now VW California 180 4 Motion.
Post #48624 15th Dec 2010 12:08pm
Lorryman100
I have the STIHL RE128 high pressure washer with a 30m hose extension. I bought this new in 2003 for about �250 and have used it every week since with no repairs or servicing in this entire time. Couldn't find my pressure washer as they seem to have changed the cosmetic look of it so here's a link for the new look model:
http://www.mowdirect.co.uk/acatalog/STIHL_PRESSURE_WASHERS.html
I'm sure you will get a better deal if you shop around..... Thumbs Up
Post #48625 15th Dec 2010 12:32pm
DefenderOfTheEarth
Reserved a Nilfisk E140 (140 bar) one from Argos - no one else in Cornwall sells them!!
Should be able to pick it up in a couple of days time. By then, my hose will be frozen solid! Defender 110XS SW gone... now VW California 180 4 Motion.
Post #48710 16th Dec 2010 12:40pm
jst
i have a karacher HW washer, had it 2nd hand and its a very good bit of kit. i have had it 4 years now. Karacher have provided superb online help considering i didnt buy it new (needed a few bits when i got it) stuff is quite �� though. we also have local dealer/mender where i can source bits from.
consider flow rate as much as pressure when choosing.
In short you get what you pay for. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #48795 17th Dec 2010 11:51am
DefenderOfTheEarth
Flow rate on the E140 is 500 litres and hour which seems pretty good.
Anyone got a snow foam lance? Worth getting? Defender 110XS SW gone... now VW California 180 4 Motion.
Post #48817 17th Dec 2010 3:57pm
TC
Get this one http://www.monzacarcare.com/snow-foam--lan...m-lance/0/
In terms of the connection, I think you need the Kew/Alto but be safe and google it first (or drop them a line). I also use valet pro snow foam (same site) with a litre lasting 7 or 8 months (an inch of snow foam juice into a full lance bottle of water)
It isn't cheap but you will see where the money went when it arrives - solid build quality and consistent spray every time. It is a reassuringly heavy piece of kit. Mine has been used continuously and still looks and operates like new.
Post #48823 17th Dec 2010 4:09pm
DefenderOfTheEarth
Cheers TC - might well get one of those. Defender 110XS SW gone... now VW California 180 4 Motion.
Post #48824 17th Dec 2010 4:43pm
TC
Also, if you use wax on the 335d, the snowfoam is PH balanced so it won't strip the wax off. I sold a 58 plate M3 coupe to make way for the Defender; that car was professionally detailed at considerable cost as it had been washed with wire wool (or at least it looked like it) before I picked it up. Using the snowfoam, megs shampoo and megs polishes I retained the prof detail finish for over 12 months......
Did the first wash of the defender at the weekend - comes up a treat
Post #48826 17th Dec 2010 5:25pm
Page 1 of 4 1234>
