Home > Technical > Won't go in a straight line!
adseybear
Canada
Why won't my 90 stop pulling to the left?!
Alignments been done several times, brakes don't seem to be binding, what else could it be? 2003 Defender 90 Td5 CSW Belize Green - "Betty"
1958 Series IIA 109 Station Wagon - "Randolph" - Awaiting Restoration
2019 Jeep Wrangler JL Rubicon - SOLD
2006 Volvo V70 D5 - Ocean Race Edition, SOLD
2003 VW Passat Estate 1.9TDI - SOLD
2008 BMW 320D M Sport Estate - SOLD
2001 Defender 90 Td5 Hard Top - SOLD
Post #484826 23rd Dec 2015 2:43pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Tyre pressures?
Was it front or 4 wheel alignment? I have seen people over tighten the front radius arms and this has caused issues. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #484833 23rd Dec 2015 3:00pm
JWL
Radius arm bushes, worth a good looking at
Post #484837 23rd Dec 2015 3:25pm
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
If everything else has been checked and is straight, try swapping the front wheels around. I cannot explain why, but it works very often even on far more sophisticated vehicles than the Defender. Defender is easier than most as the tyres arenīt directional.
I had a similar issue on mine (puling, at over 60 mph), and didnīt want to believe in it....it worked a treat!
MTīs with 20000 miles on them. 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MTīs,
Recaro CSīs, anorak, wellingtons
Post #484868 23rd Dec 2015 5:26pm
X4SKP
Hello adseybear
If pressures and tracking are good Wild Card 90 could be right,
go for fronts first, swap and check, tyres can take up an unseen 'profile'
especially if they have a few miles on them...give it a go.
Generally Rotate L to R / F to B every so often... Thumbs Up
Good Luck... SKIP
Post #484872 23rd Dec 2015 5:33pm
uncas
Front left brake sticking?
Uncas
Post #484999 24th Dec 2015 12:31am
dgardel
Italy
Driver drunk ? Mr. Green Mr. Green Mr. Green Thumbs Up Thumbs Up Thumbs Up Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #485022 24th Dec 2015 8:11am
adseybear
Canada
It's done it through two sets of tyres now, and I regularly rotate wheels/tyres round. Did it alot worse on 265 muds, now improved back on 235 Conti AT's.
As it tends to start shifting left and right under heavy braking I think going down the route of replacing bushes etc. is probably my first port of call. 2003 Defender 90 Td5 CSW Belize Green - "Betty"
Post #485024 24th Dec 2015 8:17am
Nevillerover
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Sumatra Black
has it ever been in a side shunt?
Post #485037 24th Dec 2015 8:51am
adseybear
Canada
I had a jaguar clip my rear end on a roundabout once, nothing too serious, more a glancing blow so cant have done much. 2003 Defender 90 Td5 CSW Belize Green - "Betty"
Post #485125 24th Dec 2015 2:47pm
Bumpymike
United Kingdom 1992 Defender 90 200 Tdi SW Bronze Green
Steering damper ?
I once had a similar problem and steering damper had taken a knock - it wouldn't let the steering geometry self centre the steering so pulled over to one side
Post #485188 24th Dec 2015 7:28pm
Wild Card 90
What he said👍 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
Post #485204 24th Dec 2015 8:42pm
PCA42
England 2008 Defender 110 Puma 2.4 DCPU Tonga Green
I had this issue with my 110, tried swapping the wheels around etc etc. Ended up being the original General Grabbers. Once I had replaced the tyres with new Coopers, the vehicle drives straight as a die.
However, you have said that you've had a different set of tyres on the vehicle, so this won't be of much help! Pete
2010 Discovery 4 GS TDV6
1972 Series III 88" 2.25P
Post #485232 24th Dec 2015 11:03pm
miker
If it's wandering worse under braking, that sounds like bushes to me. Might be worth checking the track rod end as well.
Post #485316 25th Dec 2015 10:21am
sv130
It could be the front offside brake piston sticking, therefore being slow to operate. Allowing the nearside brake to do all the work, which would pull the car to the left.
Gaz https://s3-eu-west-2.amazonaws.com/i.hubnu...e851ad.jpg
Post #485372 25th Dec 2015 3:33pm
