Home > Maintenance & Modifications > One Piece Bonnet Chequer Plate |
jddisco200tdi Member Since: 22 Jul 2008 Location: Melbourne, Australia Posts: 21 |
When installing the one piece bonnet plate, do you need to use a foam gasket underneath?
Also, has anyone had corrosion of the alloy wing top / galvanised bonnet by using stainless steel fasteners ? Im thinking I will use aluminium or nylon pop rivets instead. Regards John D - Defender 110 2.4 |
13th Dec 2010 5:52am |
jerseyman Member Since: 21 Jul 2009 Location: Jersey Posts: 279 |
After drilling the holes touch in with an etch primer. Use Duralac on the Stainless Steel nuts and bolts. Plastic washers would also reduce the contact areas.
On my TD5, having ground out over 100 rusty rivets I refitted some of the chequer plste using Aluminium Rivnuts, partially as an isolation layer, partially for ease of refitting Brian |
13th Dec 2010 9:56am |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 |
If it is the Mammouth 4x4 one piece bonnet chequer plate it comes with a pre-cut gasket.
Glyn |
13th Dec 2010 4:52pm |
landydubai Member Since: 01 Sep 2010 Location: Dubai Posts: 206 |
Mammoth checker ............ fitted it in June this year even with a few tweaks it still has a gap at the bonnet bulge front edge. Been off and on several times but still unable to close gap used the supplied gasket rivet nuts etc poor fit LandyDubai
Keep the shiny side up! 09 110 XS BAS remap 09 90 pick up BAS remap 08 D3 V8 G4 Spec Bentley Speed GT 2009 G55 2003 Ford Raptor 2010 - new toy! |
13th Dec 2010 7:44pm |
Mammouth 4x4 one piece bonnet chequer plate it comes with a pre-cut gasket - poor fit LandyDubai
13th Dec 2010 7:47pm |
Just a quick note on this..... they had mentioned it to me that certain age vehicles have slightly different bonnet shapes and I know they have modified manufacturing to accommodate this.... might be an idea to ask your supplier ... might get a replacement item that fits better :thumbsup Glyn |
13th Dec 2010 8:50pm |
Cheers Spent hours on the phone from dubai with Mammouth but they stated that they had no issues at the time and basically washed their hands also had the local LR specaist body shop look at it and refit it with no improvement. they spoke to Mammouth and got the same response
Anyone had the same issues mine is 2009 LandyDubai Keep the shiny side up! 09 110 XS BAS remap 09 90 pick up BAS remap 08 D3 V8 G4 Spec Bentley Speed GT 2009 G55 2003 Ford Raptor 2010 - new toy! |
14th Dec 2010 6:06pm |
Thanks for all the responses, and it is the Mammouth 4x4 one piece bonnet chequer plate .
I think i will use aluminium pop rivets and prime all the holes first before fastening. Regards John D - Defender 110 2.4 |
14th Dec 2010 10:02pm |
