Home > Technical > EGR Change
Smudger
United Kingdom 2008 Defender 110 Puma 2.4 SW Stornoway Grey
EGR Change
Guys,
Is the EGR particularly difficult to change? Any tips?
Smudger 08 110 Puma Station Wagon
65 Jaguar XF Sportbrake S
99 Elise 111S
Honda XR250
42 Royal Enfield Flying Flea
43 Matchless G3L
Post #483487 18th Dec 2015 8:24pm
Not difficult but a sod to get at.
WD40 the bolts the night before and torque them to the right figure when tightening.
Never over tighten.
Lowest bolt may be better access from underneath but you need to be fairly long armed.
Thumbs Up
Post #483490 18th Dec 2015 8:38pm
Smudger
Thanks, I'm not looking forward to this! 08 110 Puma Station Wagon
99 Elise 111S
Honda XR250
43 Matchless G3L
Post #483516 18th Dec 2015 9:24pm
ericvv
Oops, after my round trip to Belgium this week, it appears that my EGR valve which is now 6 years old (was changed once under warranty in the SVX first or 2nd year), is on its way out.
The ever so gentle chuka chuka chuka cleaning cycle has suddenly turned into a much louder screaching cycle. It is not that there has been a gradual change of sound, really changed suddenly from one switch off to the next...
So, even using exclusively premium fuels like BP Ultimate are no guarantee that they will not go wrong or coke up. Guess you can call these things a consumable. Rolling Eyes
Will call the dealer after the long weekend to order a new one and then let them replace it asap.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #517600 25th Mar 2016 7:15am
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
It's a whole lot easier to do if you remove the inlet manifold!
Takes a bit more time, but makes it less of a fiddle.
Plus you get to clean out all the crap the EGR valve puts in there!
Wink 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #517602 25th Mar 2016 7:30am
^^^^ Sounds a good idea, or the old crud in there goes straight in the new EGR.
My newer one had an even shorter life so I'd imagine that was the case with it.
Very expensive consumables, to my mind not fit for purpose.
Post #517623 25th Mar 2016 9:33am
Eric
Is it not worth giving it a clean first? I'm not sure why this is seem as a disposable item if you treat the additional noises as a warning to clean. Maybe it should be removed on a periodic/mileage basis and given some preventative maintenance?
Post #517650 25th Mar 2016 11:33am
Cupboard
How do you clean them?
I gave mine a good soaking in penetrating oil, a scrub, blew it out, did that a couple of times. It still chuckas but still is throwing up faults.
Post #517674 25th Mar 2016 1:28pm
Against the exhaust flow?
Post #517688 25th Mar 2016 2:15pm
jst
Custom90Steve could you upload that pic as a pdf please so i could print it? doesnt come out as image Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #517799 25th Mar 2016 9:09pm
Gunk, brake cleaner or there are a number of products especially for the purpose.
I'd be less keen to try something like this:
especially on an engine that had a few miles under it's belt.
Post #517864 26th Mar 2016 8:31am
Nevillerover
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Sumatra Black
When the time comes I will replace it. By the time you've bought that stuff and done all that faff to get a not particularly good result, it can't be worth it.
Post #517895 26th Mar 2016 10:51am
For those of you that would like the EGR WSM page regarding the EGR look here:
https://www.defender2.net/gallery/thumbnails.php?album=3646
Also available any time in 'My Gallery'.
Thumbs Up
Post #517929 26th Mar 2016 1:43pm
ericvv
Eric
So, the EGR had this abnormal loud screeching cleaning cycle for a full week. Dealer had everything ready to replace the EGR valve today. When I arrived at the dealer this morning and switched the engine off there, the oh so gentle sounding cleaning cycle suddenly was back. Shocked We switched engine on and off again a few times, but the loud screeching sound stayed away...
Dealer said they have seen this before, chance that the EGR cleaning cycle suddenly was able to remove some sticking soot. He suggested we don't do anything until it eventually comes back, worst that can happen is to get the MIL light on and engine goes into safety mode. Nothing worse can happen, so they will do the replacement if and when it would come back. We will see, said the blind man.
Post #519615 31st Mar 2016 2:58pm
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
That happened to me in the past after reverting the EGR-closed map, the EGR was making an awful squeaking sound, even when driving.
A bit of 2SO in the fuel tank got it all sorted quickly, no replacement EGR needed. And at 6.5 years and 93thou km, it's still on the original EGR and it's still working fine as far as I can tell/hear.
I also noticed that premium fuel actually make the matter worse, as if it was running dryer. Regular (branded still) fuel with a bit if 2SO from time to time and all is fine. “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
2009 2.4 Puma Defender 90 SW
1979 Land Rover Series 3 88"
Post #519622 31st Mar 2016 3:23pm
