- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Rickydodah
![](templates/vbnew/images/spacer.gif)
Do you mean the liquid came out of the stub axle where the half shaft is? There is a seal inside the stub axle which seals around the half shaft to stop rear axle oil from migrating into the hub bearings. Some owners remove this seal and use rear axle oil to lubricate the hub bearings instead of grease. Provided that the axle breather is clear a slight amount of oil passing the seal is not really an issue. I started with nothing and still have most of it left!
18th Dec 2015 8:07pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
