![]() | Home > Defender Celebration Series & Classic Works > Blue Fluid Leak on the Heritage |
fathaggis Member Since: 31 May 2015 Location: taynuilt Posts: 385 ![]() ![]() |
overdose of thread lock fluid
Ryderoo Member Since: 28 Aug 2015 Location: South Oxfordshire Posts: 1666 ![]() ![]() ![]() |
Is it coolant?
Should not speculate, just return it. Cheers Simon I can explain it to you, but I can't understand it for you 1990 110 TD5 county, my first Land Rover - gone 2012 Discovery 4 XS SDV6 - gone 2014 Discovery 4 XS SDV6 - gone 2015 Evoque SD4 dynamic - Wife’s - gone 2015 Urban Truck 90 XS Santorini Black Hard Top - Reluctantly gone 2020 Discovery 5 Eiger Grey 3.0 SE - gone March 24 2021 Defender S D250 Santorini Black 110 HT - gone March 24 2023 Evoque P300e SE wife’s current vehicle |
GreenHue Member Since: 28 Aug 2015 Location: Derbyshire Posts: 23 ![]() ![]() |
It's very thick,sticky and viscous
Definitely not coolest Wanted a Defender for 30 years - now own the best - A Heritage 2015 90 SW Heritage 2014 RR Sport 2014 RR Evoke |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6318 ![]() ![]() ![]() |
I'll ask my mate Steve he had the same. I'm sure it was a box out job.
so you might just want to call the dealers and get them to sort it. ![]() |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1822 ![]() ![]() ![]() |
Surely just a new family member marking its territory?
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 ![]() ![]() |
could it be blue hylomar? (gasket sealant) My 109 thread
my youtube channel |
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2025 ![]() ![]() |
Whatever it is, it's a brand new car and needs sorting out by the Dealer.
Good to know that even with the run out models the build quality is no different. ![]() 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
I have sent the photos to the dealer.
The service department are unsure as to what the blue fluid is. It will have to go in for closer inspection. Perhaps is a secret ingredient exclusive to the heritage. Just something else to make it special!! Wanted a Defender for 30 years - now own the best - A Heritage 2015 90 SW Heritage 2014 RR Sport 2014 RR Evoke |
Looks like prop grease colour.. I had a custom prop built by GKN the other week and this matches the colour!
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 ![]() ![]() ![]() |
^^ could be ^^
I use JCB grease on my props and it looks the same colour, also tends to have a blue oily "run-off" from the excess that looks the same as that. |
As it's new, it kinda makes sense. Easy fix....clean the floor, job done
toby9946 Member Since: 23 Sep 2015 Location: Hampshire/London Posts: 96 ![]() ![]() ![]() |
I found this underneath my new landmark as well... Apparently it's AddBlue or something similar to do with emissions, or at least that's what my dealer told me!
Haven't seen anymore since I wiped it up but interesting to hear what you get told too! -2015 Defender 90 XS Landmark- |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 ![]() ![]() ![]() |
^^ What a load of tosh!
Defenders don't have adblue for a start and secondly if it did it should be no where near the transfer box let alone leaking out of it! Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter ![]() |
I did think I was being fed a line at the time but it hasn't reappeared since I cleaned it up so not been too concerned!
I didn't think that any fluid was usually blue, gear oil is usually red isn't it? -2015 Defender 90 XS Landmark- |
