Home > Maintenance & Modifications > Dirt D-Fenders with Chequer sills?
RRUK
I have been told this is impossible to do but I simply don't believe that. Noting is impossible, just more of a challenge and therefore fun!
Has anyone fitted the Dirt D Fenders to a car with the chequer plate side sills?
As they simply rivet to the sill panel, I don't see why they can't be riveted to the chequer plate? 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #483029 17th Dec 2015 10:37am
camelman
I've just fitted mine (without chequer plate ), the only issue I could see with chequer plate is that they are quite a good fit on the existing set up so if the chequer plate adds another 3or 4 mm depth to the sill they might not line up perfectly with the flexible arch. I could see why they won't fit with rock sliders etc.
That aside, I was surprised at how good a job they do at keeping the crud off the side of the car. I'm running 285s on ET0 wheels so the edge of the tyre is effectively 58mm further out than standard boosts and there is very little spray up the side of the car now (before this I'd wash the car and it was filthy again an hour later...)
Post #483034 17th Dec 2015 10:54am
RRUK
Am I right in thinking they do not fix to the arch, just to the sill? 2016 D4 HSE
Post #483036 17th Dec 2015 10:56am
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
I fitted min ages ago and used a small grinder to take a bit off the chequer plate, I did have some pictures on here but can't find them now, if I get time later I'll put some on here for you, but I removed the chequer sills as they were bolted on not riveted, then just took a small amount off, didn't fit very well without grinding but they fit perfectly now. This is the only pic I can find at the moment...
Post #483037 17th Dec 2015 11:00am
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
The front Dirt Defenders attach to both the sill and the plastic wheelarch, and fit really well, even with chequer plate. No gaps, and they do an excellent job. If only attached to the sill, they will probably get pulled off when doing something Defender-like... Rolling Eyes
 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MTīs,
Recaro CSīs, anorak, wellingtons
Post #483038 17th Dec 2015 11:03am
camelman
They fit to the sill (3 holes) and the arch (2 holes).
I just used some small stainless self tappers with mine to save having to drill the rivets out if I ever need to remove them.
Probably going to get them sprayed in the New Year to match the body.
Here's a pic with them fitted, they're more subtle than fitting the whole wider arch setup.
Post #483040 17th Dec 2015 11:07am
X4SKP
Hello RRUK
Whilst I agree with your sentiment 'nothing is impossible'
I think the issue is that these are formed to take up the space between the standard profile for the lower sill and wheel arch so the addition of chequer plate, and its relief pattern as it wraps around the lower edge of the sill make this a less than ideal (clumsy) fit in these circumstances.
I looked at these also, and are going down the custom route (as is so often the way with the Defender) I'm making a set from Nylon and Stainless Steel (like my Mad Flap Brackets)...you can just see the pre-drilled holes in the wheel arch 'extensions' ready for these.
Hummm...having just read the above I may take another look... Shocked SKIP
Post #483041 17th Dec 2015 11:08am
Wild Card 90
It is interesting to compare the shots from above, with and without chequer plate. You can see that with the chequer plate they sit a little further outboard. Still fit very well.
An excellent product.
 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
Post #483048 17th Dec 2015 11:36am
TJ101
Well worth the effort Thumbs Up
 California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #483054 17th Dec 2015 11:48am
Enid_Puceflange
Scotland 2002 Defender 110 Td5 DCPU Baltic Blue
I personally agree that these are a great idea,
But also like to acknowledge that without them, the vehicle has a certain signature mark after being off road with the splashes! My confidence has been writing cheques that my abilities can't cash for years.
Post #483231 17th Dec 2015 11:10pm
TJ101
And, as soon as you hit the tarmac, you have to stop, and clean off both front door glass's, as its totally cover with crap !! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #483241 17th Dec 2015 11:42pm
Enid_Puceflange
It's all about throttle control Wink My confidence has been writing cheques that my abilities can't cash for years.
Post #483244 17th Dec 2015 11:49pm
RRUK
Here's 2 defenders, having been out in the same terrain all day, one with Dfenders and mine without, you can see the difference, and this was a clean day by comparison to other days shooting I've had recently, the entire side of the car gets sprayed.
 2016 D4 HSE
Post #483245 17th Dec 2015 11:52pm
Enid_Puceflange
I am going to get a pair fitted to my 90 Thumbs Up
G
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  My confidence has been writing cheques that my abilities can't cash for years.
Post #483249 17th Dec 2015 11:55pm
Terryt
Picked up these today ,will be fitting them tomorrow and I have chequer plate fitted so will see how it goes..
Post #484570 22nd Dec 2015 7:40pm
