Home > Td5 > sliding fan control switch
Motoberg
I've removed the instruments to change out the 2 speed fan control switch but there's also a cable at the base of the unit that moves as you slide the lever. Does anyone know what this does ?
Thanks
Post #481718 13th Dec 2015 10:43am
rallysteve
Opens and closes the fresh air inlet flap 02' 110 TD5 Double Cab Rebuild Thread
Post #481726 13th Dec 2015 11:02am
Motoberg
Cheers Rallysteve
That means my cunning plan of replacing the sllder with a rocker switch won't work..... rats !!
Post #481743 13th Dec 2015 11:40am
rallysteve
You could just lock it open all the time if you wanted. 02' 110 TD5 Double Cab Rebuild Thread
Post #481835 13th Dec 2015 6:25pm
