Home > Td5 > sliding fan control switch |
Motoberg Member Since: 01 Oct 2015 Location: Aberdeen Posts: 104 |
I've removed the instruments to change out the 2 speed fan control switch but there's also a cable at the base of the unit that moves as you slide the lever. Does anyone know what this does ?
Thanks |
13th Dec 2015 10:43am |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2237 |
Opens and closes the fresh air inlet flap 02' 110 TD5 Double Cab Rebuild Thread
13th Dec 2015 11:02am |
Cheers Rallysteve
That means my cunning plan of replacing the sllder with a rocker switch won't work..... rats !! |
13th Dec 2015 11:40am |
You could just lock it open all the time if you wanted. 02' 110 TD5 Double Cab Rebuild Thread
13th Dec 2015 6:25pm |
