Home > Puma (Tdci) > Rough idle |
glow plugs not all working for cold start
13th Dec 2015 11:19am |
SimonDavies Member Since: 15 Mar 2012 Location: Swansea Posts: 244 |
I know on a transit van with the 2.4 puma, after changing the vcv, along with the valve in the fuel rail, a pcm update is required.
If the pcm is not updated, this can cause the valve in the rail to 'blow' again. It may be worth, if you haven't already, taking the valve off and checking it is still in one piece and the innards haven't come out. Some others may have to correct me but I'm pretty sure I have this right. |
13th Dec 2015 11:26am |
Eau02467 Member Since: 20 May 2015 Location: Glasgow Posts: 48 |
Glow plugs all removed, checked and all wiring checked and all working
VCV PCM learning was done after installation I.e correctly installed so if it is knackered it was a faulty replacement unit |
13th Dec 2015 11:38am |
