Home > Technical > Slight grinding sound from the rear in 6th gear
moodyfay
Switzerland 2007 Defender 110 Puma 2.4 CSW Stornoway Grey
I have a 2007 Defender 110 (puma) and have had no problems with the car since new. I have covered over 45'000 kms with it and the car has started making a grinding sound that seeems to originate from the rear when cruising at motorway speeds in 6th gear. However, the grinding sound only occurs when I lift my foot off the accelerator pedal and only when cruising at over 130 km/h.
Do you guys have any ideas for me?! I really appreciate it, thanks
Moody
Post #4817 19th Nov 2008 12:10pm
mrwoo
United Kingdom 2004 Defender 90 Td5 CSW Epsom Green
130KM or 80MPH is quite excessive.
Post #4818 19th Nov 2008 12:51pm
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
Sounds like the rear diff to me
Post #4823 19th Nov 2008 1:23pm
Japseroony
England 2016 Defender 110 Puma 2.2 XS CSW Montalcino Red
It could be the rear propshaft. When the UJ's get worn the prop can vibrate (actually they do this from new but dont usually rumble) causing a rumble sound especially upon decelaration (sounds similer to a bearing going).
Get underneath and have a look at the joints and also check the bolts are tight.
Russell.
Post #4824 19th Nov 2008 2:45pm
moodyfay
Thank you Russell,
I will get under the car this weekend for a look. Will keep you posted!
Moody
Post #4855 21st Nov 2008 5:29pm
felos
Greece 2008 Defender 110 Puma 2.4 CSW Epsom Green
In my car it was the rear diff.It developed exactly the same problem at approx.5000km and gradualy the noise started to appear at 4th ,5th and 6th gear from 80 to 130 km/h.
The local dealer changed the front diff the transfer box and both propshafts before shorting it out (poor thing).
Hope that helps.
George NOT A TRANSIT
Post #5034 26th Nov 2008 6:07pm
