Home > Tdi > Hand Brake Light On startup?
shaggydog
Hi guys,
Not a problem at all as my 200Tdi has always done it...But...
Does anyone else notice when cranking on initial start-up the handbrake light ignites and then turns out the second the engine starts?
Also the Pto/gearbox light flashes on and then turns off immediately.
Does this happen for anyone else?
I didn't think they would be plugged into anything so why the flash on startup? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #481197 10th Dec 2015 11:14pm
Voltage drop on turning over, voltage can get as low as 8v for a second it two whilst cranking. Thumbs Up
Post #481198 10th Dec 2015 11:20pm
shaggydog
Ahh k
But would that make a light come on though? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #481294 11th Dec 2015 12:54pm
dorsetsmith
check wiring to and from hand brake switch Exclamation
Post #481297 11th Dec 2015 1:48pm
The brake light should be on all the time when the handbrake is on. Only ever off if the handbrake is off.
So if the light goes off at all with handbrake on check the above post regarding the switch wiring.
The light should only be on with handbrake on or if brake fuid level is low. Whilst driving it should be completely off.
Post #481311 11th Dec 2015 2:44pm
shaggydog
It doesn't have a handbrake switch and it never illuminates apart from on start up with the pto box light Confused Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #481317 11th Dec 2015 3:06pm
I would say normal.
Brake fluid level all good?
Post #481324 11th Dec 2015 3:39pm
shaggydog
Yeah brake fluid is fine Thumbs Up
Its purely a curiosity thing as its always done it so was just wandering why it is.
I'm not going to start pulling the dash apart to follow wires though..
Its not THAT interesting Laughing Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #481333 11th Dec 2015 3:58pm
Mountain_man
Wales
Early ones had a brake check light. Not sure how it works but was designed to work via a relay to give a light at start up and go out if all was OK with the brake pressure unit. I think.
Post #481337 11th Dec 2015 4:31pm
tonyhedge
2014 Defender 90 Puma 2.2 SW Montalcino Red
I haven't got a 200Tdi to look at so I may be mis-remembering, but I think they come on as a self-test just to confirm the light is working, then go off. Cranking may be pulling the volts low enough to retrigger the self-test. That's not a dent, it's a rivet. That's not a dent, it's a rivet. That's not ... oh! That is a dent!
2014 90 XS SW
1997 Discovery 300TdiS (retired to stud)
1966 Series IIA 88" (now my son's)
2001 Astra - I need something to go and buy the parts when the others are off the road!
Post #481338 11th Dec 2015 4:38pm
Mountain_man
Wales
Info in this post. Read reply 8. Quite possible that this is your light. If you have the Pressure Differential unit then I guess it is all working OK
http://forums.lr4x4.com/index.php?showtopic=52567
Post #481339 11th Dec 2015 4:38pm
jst
Good find Pikey Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #481367 11th Dec 2015 6:17pm
shaggydog
Possibly, but wouldn't that show up on the Brake warning light rather than the Handbrake light?
And why would it also operate the pto light? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #481378 11th Dec 2015 7:15pm
Retroanaconda
Brake warning light illuminates with key at position III (i.e. start) as a bulb check.
Mine does it and always has. No pressure differential warning thingy either as its a 90, just a G-valve on the rear brake line. The brake warning light is otherwise only triggered when the fluid is low.
Post #481499 12th Dec 2015 10:45am
Mo Murphy
Concur with retro above, it comes on as a bulb check.
50 Shades of Pennine Grey
Post #481501 12th Dec 2015 10:46am
