Home > Td5 > Front door seals (lower)
Page 3 of 4 <1234>
Tank
Scotland 2004 Defender 90 Td5 HT Zermatt Silver
Lambley wrote:
Fitting the new type seals to a Td5 is easy, I've fitted them to mine and they give a much better seal. Remove the door card, drill out the rivets, enlarge the rivet holes my 1mm, drill a couple of extra holes for the side bits, Hoover the rivets etc from inside the door, clip new ones into place.
What year is your TD5 Lambley
Post #481105 10th Dec 2015 7:32pm
Justtellme
Canada 2003 Defender 110 Td5 SW Oslo Blue
Can anybody confirm that these seals will fit a 2003 TD5??
My old ones are about to fall off and need replacing.....if the new style fit, now would be the time to do it.
thanks for any info!
Patrick
Post #482745 16th Dec 2015 2:03pm
Martin
Site Admin
Some Td5s have the so called "Puma" pressed frame doors, the change over was part way through 2005MY.
But *if* you are not the first owner of your 2003 you cannot know that the doors have not been changed in the past
You need to do a visual inspection of the door frame to see if it a smooth one-piece part or a fabricated square-section construction.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #482751 16th Dec 2015 2:35pm
Justtellme
Aha!
That explains it. I thought it was td5 vs puma thing. My doors are original and have the welded square bottoms on the front, so I suppose I am out of luck. Were the rear doors also upgraded in 2005? Will the new seals fit the older rear doors?
Patrick
Post #482758 16th Dec 2015 3:34pm
excossack
I have the seals for the rear doors (behind driver and passenger) and they look to fit OK.
For the fronts, if I go later Puma door seals I might be tempted to break out the grinder and curve the bottom corners to match the door seals and re-weld a plate in. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #482896 16th Dec 2015 7:35pm
ericvv
driver9 wrote:
Foam block 85p from a LR dealer and free delivery.
http://www.shop4landrover.co.uk/product/FOAM_BLOCK_AWR3140
Oopsie. Price has changed to the general going rate now.
But kudos to Beadles Land Rover who took the mistake on their website in good spirit and who did honour my order without questons, so I got 16 of these blocks at 0.71£ a piece net of VAT and with free shipping to Switzerland.
Just installed 5 of them on the SVX to replace the ones that had gone amiss with time. Need to manage my remaining stock sparingly. Whistle
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #486573 29th Dec 2015 1:38pm
excossack
2nd row doors now have the new style door seals. Not long to fit as I had no seals to begin with.
Rough order:
Undo the nut holding the door limiter in place.
Place a towel between the door frame and the A piller
Ran some masking tape the length of the door frame and up the sides
Got the correct handed door seal out the bag
Did a test fit so I could see the location of the holes needed for the studs.
Put blobs of paint on the ends of the studs and offered up the door seal
Using the paint marks on the masking tape, then proceeded to drill the holes. Started off small with a pilot drill and then finished with 5mm
Removed the masking tape
Put some paint in and around the holes to cover the bare metal.
Put the door seal in place and squirted some cavity wax into the fold on the door frame for the door skin.
Doors closed fine.
As a test I put some blobs of paint on the floor where the seal meets and then paint transferred to the door seal. Wiped off with some white spirit.
Jobs a goodun!
The test will be a run on the motorway to if the road noise has been reduced.
Before/Masking tape
After
Regards
John M0VAZ
Post #490299 9th Jan 2016 4:10pm
EWS
United Kingdom 2006 Defender 90 Td5 HT Alveston Red
Hi all.
Just fitted these new style door bottom seals to our '06 Td5, easy job and well worth doing. Just requires a little more effort to close the doors. Just a brilliant idea.
Thanks to the advice on here.
Edward
Post #495555 23rd Jan 2016 5:37pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Yesterday I installed the new style door seals on my 2000MY 110. Easy to do, just wanted to demonstrate that they can be installed on older style (square welded) doors. Thumbs Up
 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #516195 20th Mar 2016 4:22pm
excossack
Do you find the door seals any better over the original ones?
I might replace mine with the later seals instead of the single strip across the bottom of the door, 1999 Defender TD5 110
Regards
John M0VAZ
Post #516386 21st Mar 2016 12:11pm
4RF RDS
Substantially better. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #516394 21st Mar 2016 12:30pm
excossack
Could be a worth while investigation.... 1999 Defender TD5 110
Regards
John M0VAZ
Post #516406 21st Mar 2016 1:25pm
Lancerdoc999
Are these seals still going well on the earlier Td5 doors?? Looking at adding this to list of upgrades??
Post #534422 24th May 2016 11:27pm
4RF RDS
Absolutely one of the best upgardes I've done. The trick is to use a dremel tool to make new plastic clip holes in the rubber. You then move the clips in the rubber to match the holes already on the door frame for the old style bottom seal. Otherwise you drill a few new holes... No big deal I suppose but easier in my opinion. They work great on the old style door frame. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #534425 25th May 2016 12:33am
Lancerdoc999
more time and money required then! Someone write that cutting new holes in the rubbers might make then tear. Is this likely?
Post #534618 25th May 2016 5:39pm
Page 3 of 4 <1234>
