Home > In Car Electronics > Battery Ah
dilukabey
2009 Defender 110 Puma 2.4 SW Keswick Green
Battery Ah
Hello everyone. I thought of replacing my current battery. What Ah value LR recommends? Since I use my 12000lbs Winch+fog lamps and other mods is it OK to go for a higher Ah value? Can higher Ah value cause any harm to the electrical system of the vehicle ?
Cheers.
Regards
Diluk
Post #480680 9th Dec 2015 3:45pm
mikeh501
just get the biggest one which will fit in your battery box. numax 1000 is a good battery. 1000 CCA. The Ah value determines how much capacity the battery has.
Post #480811 9th Dec 2015 8:39pm
jimbob7
Halfords sell a Yuasa battery (factory fit for most Jap/Euro motorcycle factories Thumbs Up ) CCA 900 amp,5yr guarantee.
Halfords often have a 10% sale on ....if you can wait!!Think the very excellent standard fit LR battery is about 750cca?? Pov.spec,ftw. 2006, 110,TD5.
Post #481022 10th Dec 2015 3:07pm
Motoberg
Your electrical equipment will be fine with a bigger powered battery ( as long as its 12v Smile )
They will only pull as much current as they need
Post #481036 10th Dec 2015 3:52pm
ericvv
Here is the answer by tatra805
tatra805 wrote:
Original battery is a Varta Profesional Deep Cycle Marine Leisure , 90Ah/800CCA, code LFD90
 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #481046 10th Dec 2015 4:35pm
