![]() | Home > In Car Electronics > Battery Ah |
dilukabey Member Since: 17 May 2011 Location: Sri Lanka Posts: 173 ![]() ![]() |
Hello everyone. I thought of replacing my current battery. What Ah value LR recommends? Since I use my 12000lbs Winch+fog lamps and other mods is it OK to go for a higher Ah value? Can higher Ah value cause any harm to the electrical system of the vehicle ?
Cheers. Regards Diluk |
Halfords sell a Yuasa battery (factory fit for most Jap/Euro motorcycle factories
![]() Halfords often have a 10% sale on ....if you can wait!!Think the very excellent standard fit LR battery is about 750cca?? Pov.spec,ftw. 2006, 110,TD5. |
Motoberg Member Since: 01 Oct 2015 Location: Aberdeen Posts: 104 ![]() ![]() |
Your electrical equipment will be fine with a bigger powered battery ( as long as its 12v
![]() They will only pull as much current as they need |
Here is the answer by tatra805 You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
