Home > Maintenance & Modifications > Replacing door hinge pins
excossack
Is it possible to replace just the hinge pins?
When trying to adjust the doors I thought I was adjusting the doors, but could not suss why the door didn't sit right. Turns out there is play in the hinge pins.
So while I was adjusting the door, I was in fact moving the door in accordance to the amount of play in the pin! 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #480667 9th Dec 2015 2:43pm
dorsetsmith
you can drift out pin, but door hinge are only sold complete
Post #480669 9th Dec 2015 2:55pm
I have never actually managed to remove the pin from a standard Defender door hinge, though I have several times read (as above) that it is theoretically possible, and I suspect that the pin is 'upset' after fitting to swell the lower end to prevent removal.
In practice it seem that you have to replace the hinge complete.
Post #480681 9th Dec 2015 3:55pm
excossack
So new hinges it is then. Another job on the list (that does not appear to get any shorter) 1999 Defender TD5 110
Regards
John M0VAZ
Post #480706 9th Dec 2015 5:15pm
